I am unable to run .sh file in Ubuntu 14.04. The same file was executing in earlier version 12.xx. After upgrading to 14.04, this file stopped running. How to resolve this issue?
Asked
Active
Viewed 2.4k times
All that you need to do is set default action here File Manager > Edit > Preferences > Behaviour forExecutable Text Files. In Ubuntu 14.04 it is set to View Executable Files when they are opened
eldos
- 186
You can check whether or not the script is executable by doing something like:
$ ls -l nameoffile
replacing nameoffile with the name of the script. The output will look like:
-rwxr-xr-x 1 users users 848101 Mar 12 11:22 configure
The last x in the first column, means that this file is an executable. If this x is missing, it means that the file is not executable. You can easily fix this. To make a script executable, you can execute:
chmod +x /path/to/nameofscript.sh
After that to execute it from the command line, you can do:
./path/to/nameofscript
Xubu-tur referenced a very good explanation for doing this from a graphical environment.
