I have a problem with a script I wrote to install a bunch of apps, basically as it loops through an array of app names to install it checks them by doing:
dpkg -l | grep -q $i
and based on the $? will either install or skip the app. Trouble is for a few items it fails due to a dpkg lock, almost the whole list works, just half a dozen fail but work if you run the script again.
Is it possible to wait for dpkg to finish before running the 'apt-get install'?
For now I've added a 'sleep 0.5' between the 2 lines and this has stopped the problem but is obviously ugly and slower.
Thanks, Noki
Clayton
  • 1,431
Noki
  • 942
To identify processes using files or sockets you can use fuser command (see man fuser for more info). In case of dpkg, you can check for the lock as root with the following command:
fuser /var/lib/dpkg/lock
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
