I wan to take a laptop with DOS only. I want a Ubuntu 12.04 Boot-Able CD do that I can boot my system at any time whenever needed. How can I make a boot-able CD? Can you please tell me the complete procedure for that? Thanks in advance.
hellodear
  • 4,833
This seems to perfectly solve your question. Regardless of your current operating system.
https://help.ubuntu.com/community/BurningIsoHowto
I recommend using a USB stick to install ubuntu :D its.. er... reusable :D
YOU WILL NEED TO SET USB TO FIRST BOOT IN YOUR BIOS
I dont like doing this step, so what I do is during boot mash the F# keys, one of them lets you select which drive to boot from, in your case you would select the USB stick. Obviously mashing the F# keys is a bad strat but it did help me find the correct F# key. in my case its F7.
Unetbootin is a program that will let you install a ubuntu .iso from a usb stick you can download it at: http://unetbootin.sourceforge.net/
Yumi lets you use the USB stick to install ubuntu plus also use the left over space for storage. Yumi also lets you store multiple linux distros on the same USB stick. download it at: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Here is the official documentation for installing ubuntu onto a USB
https://help.ubuntu.com/community/Installation/FromUSBStick
many programs let you add "persistence" to the USB stick, which means that every time you boot using the USB stick all your changes are saved! if you read the official documentation for USB installs you'll come accross Unetbootin which is what I use when I want to add persistence.
Banned_User
  • 1,683
