23
I'm running Ubuntu 14.04 LTS, and I have an HD 4600 integrated graphics chip.
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
Intel just released the new version of their Graphics driver for Ubuntu 14.04.
https://01.org/linuxgraphics/downloads/2014/intelr-graphics-installer-1.0.5-linux
When I try to install it, I get stuck at:
Finished : E:GPG error: http://download.01.org trusty InRelease: Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)  [  ] ◦
main-window.c/on_transaction_finished: Package transaction finished with an error
And it prevents sudo apt-get update from completing. I get the same error as before.
I went to Software & Updates and under Other Software tab I removed the bad repository: http://download.01.org/gfx/ubuntu/14.04/main, and then I could update my repositories. But I cannot install the Intel Graphics Driver!
I hope I'm making sense. This is the first day this is available, so I'm counting on Intel to fix this soon, if not, I hope someone can help find a work around.
Zanna
  • 72,312
Loren Kuich
  • 243
The installer contains the wrong repository url. To fix this you need:
  1. Start the installer and try to install, you got error, close installer.
  2. Open console and type:
    sudo -H gedit /etc/apt/sources.list.d/intellinuxgraphics.list
  3. Replace text with text below, don't close gedit just leave it:
    deb https://download.01.org/gfx/ubuntu/14.04/main/ trusty main #Intel Graphics drivers
  4. Start the installer again, press Begin button, press Install button and fast switch to gedit and hold CTRL+S.
    sudo apt-get update may yield:
    GPG error: https://download.01.org trusty InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A902DDA375E52366
    Fix it with:
    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys A902DDA375E52366
Zanna
  • 72,312
xikamo
  • 496
Here's the easier solution for those with problems:
  1. Open Nautilus(file explorer), go to Edit -> Preferences -> Behavior, and make sure that under Executable text files, Ask each time is selected! (if not, select it)
  2. Close the window
  3. Open Nautilus (if not already open)
  4. Right click New document > Empty document
  5. Name it script.sh
  6. Open it and enter this:
    #! /bin/bash
    while [ 1 ]; do
        sudo sed --in-place 's/http:/https:/g' /etc/apt/sources.list.d/intellinuxgraphics.list
        sleep 1
    done
  7. Save it and close it
  8. Right click on script.sh and select Permissions
  9. Check Allow executing this file as program
  10. Close the window
  11. Double click it
  12. Select Run in terminal
  13. Enter password
  14. DO NOT close the terminal
  15. Begin installation, and everything should work
I also got Failed to fetch download.01.org/gfx/ubuntu/14.04/main/pool/main/i/… Size mismatch error and this fixed the problem. You can delete script file and close the terminal when the installation is finished.
Edit: There is simpler way:
  1. Enter this in terminal:
    #! /bin/bash
    while [ 1 ]; do
        sleep 1
    done
  2. Enter password
  3. Run the installer
Zanna
  • 72,312
Use gdebi to install the intel-linux-graphics-installer and you won't have the GPG problems. It should automatically install with the deb package. Use the following commands to do so:
sudo apt-get update && sudo apt-get install gdebi
cd && wget https://download.01.org/gfx/ubuntu/14.04/main/pool/main/i/intel-linux-graphics-installer/intel-linux-graphics-installer_1.0.6-0intel1_amd64.deb
sudo gdebi intel-linux-graphics-installer_1.0.6-0intel1_amd64.deb
Follow the instructions displayed in the GUI to update your system. Save any unsaved work and reboot for the changes to take effect.
Furthermore, using
sudo apt-key adv
Is considered a security risk and is not recommended as you are "undermining the whole security concept as this is not a secure way of recieving keys for various reasons (like: hkp is a plaintext protocol, short and even long keyids can be forged, …)". http://ubuntuforums.org/showthread.php?t=2195579
I believe the correct way is to first import the key
GET https://download.01.org/gfx/RPM-GPG-KEY-ilg | gpg --import
Check the fingerprint
gpg --check-sigs --fingerprint 75E52366
Get the key from the keyserver
gpg --keyserver pgpkeys.mit.edu --recv-key 7CB0FA13
Export the key to your keyring
gpg -a --export 75E52366 | sudo apt-key add -
Repeat for second key
GET https://download.01.org/gfx/RPM-GPG-KEY-ilg-2 | gpg --import
gpg --check-sigs --fingerprint 2F4AAA66
gpg --keyserver pgpkeys.mit.edu --recv-key 144BD458
gpg -a --export 2F4AAA66 | sudo apt-key add -
more info http://www.debian.org/doc/manuals/securing-debian-howto/ch7.en.html#s-deb-pack-sign
mchid
  • 44,904
  • 102
  • 162
