I have 2 ethernet cards (built into my motherboard) and 1 wireless card (assigned via dhcp as 192.168.1.67 by my ATT dsl modem/router) on my linux box. Wireless works fine. I tried using Network manager to configure eth1 but when I entered the desired IP address and Network Mask (255.255.255.0) then clicked save, the setting wouldn't take. If I immediately typed "ifconfig" I would get this:
eth0      Link encap:Ethernet  HWaddr 00:04:4b:15:45:77
      UP BROADCAST MULTICAST  MTU:1500  Metric:1
      RX packets:0 errors:0 dropped:0 overruns:0 frame:0
      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth1      Link encap:Ethernet  HWaddr 00:04:4b:15:45:78
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:501 errors:341 dropped:18 overruns:340 frame:1
      TX packets:457 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:57297 (57.2 KB)  TX bytes:45203 (45.2 KB)
lo        Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:1119 errors:0 dropped:0 overruns:0 frame:0
      TX packets:1119 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:105359 (105.3 KB)  TX bytes:105359 (105.3 KB)
wlan0     Link encap:Ethernet  HWaddr 00:c0:ca:36:46:12
      inet addr:192.168.1.67  Bcast:192.168.1.255  Mask:255.255.255.0
      inet6 addr: fe80::2c0:caff:fe36:4612/64 Scope:Link
      RX packets:14035 errors:0 dropped:0 overruns:0 frame:0
      TX packets:8356 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:14142088 (14.1 MB)  TX bytes:1208084 (1.2 MB)
It is obvious that eth1 was not configured even though I just configured it using the network manager tool. It's as if I didn't do anything. So I searched the web looking for something... something to enlighten me. I eventually found someone with a somewhat similar problem. So I started to follow what they did and here is some of what I did.
Dump of /etc/NetworkManager.conf
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
no-auto-default=00:04:4B:15:45:77,
[ifupdown]
managed=true
Notice the "managed = true." I changed that. It previously said, "managed = false."
I then went into the /etc/network/interfaces file and added the text starting at "# The primary hard-wired network interface"
/ect/networks/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
  # The loopback interface
  auto lo
  iface lo inet loopback
  iface eth1 inet static
  address 192.168.1.4
  netmask 255.255.255.0
  gateway 192.168.1.254
Then i save that and tried restarting network services. Nothing changed so after changing that file I typed:
ifconfig eth1 192.168.1.4 netmask 255.255.255.0 up
I typed ifconfig and I could see the card was configured with the network address I wanted. Things started to look promising but of course I wouldn't be typing this if I got it working.
So I tried pinging the 192.168.1.4 address from another computer (192.168.1.6) on the same wired network, but If I tried the reverse by pinging that other computer(192.168.1.6) from 192.168.1.4 it would just hang there forever displaying:
frequencydrive@Hacker:~$ ping 192.168.1.6
PING 192.168.1.6 (192.168.1.6) 56(84) bytes of data.
It would just hang there not responding to the ping. I also noticed that I could no longer surf the internet. If I tried going to google immediately after using the "ifconfig eth1 192.168.1.4..." command shown above I could not get anywhere using Firefox. It seemed to lose it's route to the default gateway? If I brought down the interface by typing:
sudo ifconfig eth1 down
I could immediately surf the web.
What the heck is causing all this? I just want a wired network and a wireless network all on the same 192.168.1.x address space.
Some of the things I did I got from this thread:
Trying to configure eth0 and eth1 but Failed to bring up eth1
I've been working on this problem for days. It's so frustrating. Why does networking have to be so hard with Linux?
Thanks for any help.
