So I started messing around with Compiz a bit
I enabled window decorations but that made me disable unity plugin
So no launcher and no task bar or whatever it's called in Linux I accidentaly minimised the Compiz Settings and POOF it's gone I opened the monitor settings to end compiz's process now am stuck with no borders at all! so I booted into Live mode just to ask here :z do I need a fresh install or is there a solution?
Rinzwind
  • 309,379
Open a Virtual Console. Ctrl+Alt+F1 to open it.
rm ~/.gconf ~/.gconfd ~/.metacity ~/.compiz-1 ~/.config/compiz-1 ~/.config/dconf -rf
And then reboot. It will remove all the settings and start Ubuntu in vanilla state.
BuZZ-dEE
  • 14,533
ajit
  • 61
Explanation
All the solutions above did not work for me. What did, instead, is this
rm -rf ~/.config/gtk-3.0
after having removed what @ajit said
rm  -rf ~/.gconf ~/.gconfd ~/.metacity ~/.compiz-1 ~/.config/compiz-1 ~/.config/dconf
How to fix it
In conclusion, Ctrl+Alt+F1, log in to your account
sudo service lightdm stop
rm  -rf ~/.gconf ~/.gconfd ~/.metacity ~/.compiz-1 ~/.config/compiz-1 ~/.config/dconf ~/.config/gtk-3.0
sudo service lightdm restart
Atcold
  • 287
-1
Install unity-tweak-tool:
Then run as normal user:
unity-tweak-tool --reset-unity
