I just deployed a handful of 14.04 systems and I'm noticing that whenever I vim something, vim is already in replace mode.
As I'm used to being in command mode on starting, this is rather disorienting.
Any idea why? I don't see any obvious culprits in /etc/vim/vimrc, but this happens with every user on the system.
Installed relevant packages:
$ aptitude search vim | grep ^i
i vim - Vi IMproved - enhanced vi editor
i vim-common - Vi IMproved - Common files
i vim-nox - Vi IMproved - enhanced vi editor - with sc
i vim-runtime - Vi IMproved - Runtime files
i vim-tiny - Vi IMproved - enhanced vi editor - compact
vim -V output:
# vim -V
chdir(/usr/share/vim)
fchdir() to previous dir
sourcing "$VIM/vimrc"
Searching for "debian.vim" in "/root/.vim,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/root/.vim/after"
Searching for "/root/.vim/debian.vim"
Searching for "/usr/share/vim/vimfiles/debian.vim"
Searching for "/usr/share/vim/vim74/debian.vim"
chdir(/usr/share/vim/vim74)
line 10: sourcing "/usr/share/vim/vim74/debian.vim"
finished sourcing /usr/share/vim/vim74/debian.vim
continuing in /usr/share/vim/vimrc
Searching for "/usr/share/vim/vimfiles/after/debian.vim"
Searching for "/root/.vim/after/debian.vim"
chdir(/usr/share/vim/vim74/syntax)
line 20: sourcing "/usr/share/vim/vim74/syntax/syntax.vim"
Searching for "syntax/synload.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/syntax/synload.vim"
Searching for "/var/lib/vim/addons/syntax/synload.vim"
Searching for "/usr/share/vim/vimfiles/syntax/synload.vim"
Searching for "/usr/share/vim/vim74/syntax/synload.vim"
line 19: sourcing "/usr/share/vim/vim74/syntax/synload.vim"
Searching for "syntax/syncolor.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/syntax/syncolor.vim"
Searching for "/var/lib/vim/addons/syntax/syncolor.vim"
Searching for "/usr/share/vim/vimfiles/syntax/syncolor.vim"
Searching for "/usr/share/vim/vim74/syntax/syncolor.vim"
line 21: sourcing "/usr/share/vim/vim74/syntax/syncolor.vim"
finished sourcing /usr/share/vim/vim74/syntax/syncolor.vim
continuing in /usr/share/vim/vim74/syntax/synload.vim
Searching for "/usr/share/vim/vimfiles/after/syntax/syncolor.vim"
Searching for "/var/lib/vim/addons/after/syntax/syncolor.vim"
Searching for "/root/.vim/after/syntax/syncolor.vim"
finished sourcing /usr/share/vim/vim74/syntax/synload.vim
continuing in /usr/share/vim/vim74/syntax/syntax.vim
Searching for "filetype.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/filetype.vim"
Searching for "/var/lib/vim/addons/filetype.vim"
Searching for "/usr/share/vim/vimfiles/filetype.vim"
Searching for "/usr/share/vim/vim74/filetype.vim"
line 25: sourcing "/usr/share/vim/vim74/filetype.vim"
Searching for "ftdetect/*.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/ftdetect/*.vim"
Searching for "/var/lib/vim/addons/ftdetect/*.vim"
Searching for "/usr/share/vim/vimfiles/ftdetect/*.vim"
Searching for "/usr/share/vim/vim74/ftdetect/*.vim"
Searching for "/usr/share/vim/vimfiles/after/ftdetect/*.vim"
Searching for "/var/lib/vim/addons/after/ftdetect/*.vim"
Searching for "/root/.vim/after/ftdetect/*.vim"
not found in 'runtimepath': "ftdetect/*.vim"
finished sourcing /usr/share/vim/vim74/filetype.vim
Searching for "/usr/share/vim/vimfiles/after/filetype.vim"
Searching for "/var/lib/vim/addons/after/filetype.vim"
Searching for "/root/.vim/after/filetype.vim"
finished sourcing /usr/share/vim/vim74/syntax/syntax.vim
line 25: sourcing "/usr/share/vim/vim74/syntax/syncolor.vim"
line 36: sourcing "/usr/share/vim/vim74/filetype.vim"
Searching for "ftplugin.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/ftplugin.vim"
Searching for "/var/lib/vim/addons/ftplugin.vim"
Searching for "/usr/share/vim/vimfiles/ftplugin.vim"
Searching for "/usr/share/vim/vim74/ftplugin.vim"
line 36: sourcing "/usr/share/vim/vim74/ftplugin.vim"
finished sourcing /usr/share/vim/vim74/ftplugin.vim
Searching for "/usr/share/vim/vimfiles/after/ftplugin.vim"
Searching for "/var/lib/vim/addons/after/ftplugin.vim"
Searching for "/root/.vim/after/ftplugin.vim"
Searching for "indent.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/indent.vim"
Searching for "/var/lib/vim/addons/indent.vim"
Searching for "/usr/share/vim/vimfiles/indent.vim"
Searching for "/usr/share/vim/vim74/indent.vim"
line 36: sourcing "/usr/share/vim/vim74/indent.vim"
finished sourcing /usr/share/vim/vim74/indent.vim
Searching for "/usr/share/vim/vimfiles/after/indent.vim"
Searching for "/var/lib/vim/addons/after/indent.vim"
Searching for "/root/.vim/after/indent.vim"
finished sourcing $VIM/vimrc
chdir(/root)
could not source "$HOME/.vimrc"
chdir(/root/.vim)
could not source "~/.vim/vimrc"
chdir(/root)
could not source "$HOME/.exrc"
Searching for "plugin/**/*.vim" in "/root/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,/root/.vim/after"
Searching for "/root/.vim/plugin/**/*.vim"
Searching for "/var/lib/vim/addons/plugin/**/*.vim"
Searching for "/usr/share/vim/vimfiles/plugin/**/*.vim"
Searching for "/usr/share/vim/vim74/plugin/**/*.vim"
chdir(/usr/share/vim/vim74/plugin)
sourcing "/usr/share/vim/vim74/plugin/getscriptPlugin.vim"
finished sourcing /usr/share/vim/vim74/plugin/getscriptPlugin.vim
sourcing "/usr/share/vim/vim74/plugin/gzip.vim"
finished sourcing /usr/share/vim/vim74/plugin/gzip.vim
sourcing "/usr/share/vim/vim74/plugin/matchparen.vim"
finished sourcing /usr/share/vim/vim74/plugin/matchparen.vim
sourcing "/usr/share/vim/vim74/plugin/netrwPlugin.vim"
finished sourcing /usr/share/vim/vim74/plugin/netrwPlugin.vim
sourcing "/usr/share/vim/vim74/plugin/rrhelper.vim"
finished sourcing /usr/share/vim/vim74/plugin/rrhelper.vim
sourcing "/usr/share/vim/vim74/plugin/spellfile.vim"
finished sourcing /usr/share/vim/vim74/plugin/spellfile.vim
sourcing "/usr/share/vim/vim74/plugin/tarPlugin.vim"
finished sourcing /usr/share/vim/vim74/plugin/tarPlugin.vim
sourcing "/usr/share/vim/vim74/plugin/tohtml.vim"
finished sourcing /usr/share/vim/vim74/plugin/tohtml.vim
sourcing "/usr/share/vim/vim74/plugin/vimballPlugin.vim"
finished sourcing /usr/share/vim/vim74/plugin/vimballPlugin.vim
sourcing "/usr/share/vim/vim74/plugin/zipPlugin.vim"
finished sourcing /usr/share/vim/vim74/plugin/zipPlugin.vim
Searching for "/usr/share/vim/vimfiles/after/plugin/**/*.vim"
Searching for "/var/lib/vim/addons/after/plugin/**/*.vim"
Searching for "/root/.vim/after/plugin/**/*.vim"
Reading viminfo file "/root/.viminfo" info oldfiles
Press ENTER or type command to continue
