I disabled the lock in the "Brightness & Lock" but I still get the lock screen when is resumes/wake from suspend. Although the option "Require my password when waking from suspend" is unchecked
Asked
Active
Viewed 3.7k times
31
There is two steps involved into completely disabling the lock screen in Unity.
- Go to
Brightness & Lockpanel from the Unity Launcher. And setTurn screen off when inactive:toNever - Install "Unity Tweak Tool" with
sudo apt-get install unity-tweak-tool. Run it from the Launcher and selectSystem > Security > Enhance system security by disabling Desktop lock
RubenLaguna
- 753
go to search , type Unity, in the options displayed find and double click on option "Unity Tweak Tool", a windows opens inside that you will find main options like
Unity
Windows Manager
Appearance
System
under "system" there are 3 sub option "Desktop" , "Security", "Scrolling"
- click on security, under security tab do a check on option "Desktop Lock"
I am adding this solution just in case if unable to find the option.
Thanks for the all previous post's. very helpful and informative.
sahil
- 1
None of these worked for me, but I found some info in this bug report.
As a result of what I read in the bug I ended up doing this:
sudo mv /etc/xdg/autostart/light-locker.desktop /etc/xdg/autostart/light-locker.desktop.bak
That seemed to do the trick.
muru
- 207,228
Integrator
- 241
