12
I created a partition for Ubuntu, and I just ran out of space a couple of days ago.
I used the Disk Usage Analyzer and I realized that for some reason the directory /home/.cache uses up a lot of disk space; specifically the tracker folder. What is recommended to do in order to prevent this cache and tracker folder to grow so much?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
ivars31
  • 123
You can "pause" the Gnome Tracker by setting the configuration option org.freedesktop.Tracker.Miner.Files.low-disk-space-limit used by tracker-miner-fs.
Values indicate if we pause indexing at a percentage of low disk space (0-100% or -1 to disable the check entirely, 3 being the default value).
Open a terminal (Ctrl+Alt+t) and type the following command to stop the tracker at 1%:
gsettings set org.freedesktop.Tracker.Miner.Files low-disk-space-limit 1
Source.
Pablo Bianchi
  • 17,371
