Ever since I upgraded my machine to 14.04 - I cannot commit via Aptana's "Team" menu.
I was having other, miscellaneous and unrelated problems, so I did a fresh install, and used Oracle Java instead, and I would've sworn to you that worked a couple of days ago.
But today, I'm having the same problem, and I can't find out why.
This is the error file it leaves behind ( hs_err_pidXXXX.log ), but I honestly can't make sense of it.. I don't see anything that defines precisely what the problem is... so I'm not even sure if it will be helpful...
http://pastebin.com/ZrCF26QS
I've tried: Installing
tk8.5 python-tk libswt-gtk-3-java git-core
The most recent thing I tried was oracle-java7-set-default in case oracle-java7-installer wasn't enough.
I also ran:
$ ulimit -c unlimited
to no avail.
Any light anyone can shed on this would be greatly appreciated...
rm-vanda
  • 3,202
OK, I got it working - //Edit : (My original fix wasn't actually what fixed it)
Oddly enough, one website suggested:
ln -s /opt/Aptana_Studio_3/AptanaStudio3 /usr/local/bin/aptanaS3
Which actually seems to be precisely what fixed the problem... Running Aptana via aptanaS3 instead of /opt/Aptana_Studio_3/AptanaStudio3 actually fixed the problem. I didn't originally mention it, because I thought I was just making a shortcut...
This is everything else I did, albeit I don't think any of this matters:
Added: -Dorg.eclipse.swt.browser.DefaultType=mozilla
to /opt/Aptana_Studio_3/AptanaStudio3.ini at the very bottom...
Also did this, which I learned from here
wget -O xulrunner.deb http://launchpadlibrarian.net/70321329/xulrunner-1.9.2_1.9.2.17%2Bbuild3%2Bnobinonly-0ubuntu1_amd64.deb && sudo dpkg -i xulrunner.deb
rm-vanda
  • 3,202
