I have a Dell Latitude E5420 laptop which I upgraded from Ubuntu 13.10 to Ubuntu 14.04 a few days ago.
I can't help noticing a new annoying behaviour of the fan: it repeatedly gets loud every 1-2 seconds, it turns off, and then on again, for minutes and without any intensive-CPU process running.
Is there any fix for this?
Ok, so the temperature does seem to increase a little bit during these loud moments. It goes quickly from 50 to 60 degrees celsius, and then it cools off and goes back to 50.
It just had never happened so often before...
Noisy:
$ sensors
acpitz-virtual-0
Adapter: Virtual device
temp1: +25.0°C (crit = +107.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0: +55.0°C (high = +80.0°C, crit = +85.0°C)
Core 0: +55.0°C (high = +80.0°C, crit = +85.0°C)
Core 1: +54.0°C (high = +80.0°C, crit = +85.0°C)
i8k-virtual-0
Right Fan: 121350 RPM
CPU: +59.0°C
Quiet:
$ sensors
acpitz-virtual-0
coretemp-isa-0000
Physical id 0: +49.0°C (high = +80.0°C, crit = +85.0°C)
Core 0: +51.0°C (high = +80.0°C, crit = +85.0°C)
Core 1: +51.0°C (high = +80.0°C, crit = +85.0°C)
i8k-virtual-0
Right Fan: 0 RPM
CPU: +50.0°C
This user, with a similar notebook model (Dell Latitude E6400), is having the exact same issue.
EDIT 2. Now the fan has been turning itself on and off for minutes, but the temperature is stable at 42 degrees Celsius:
$ sensors
acpitz-virtual-0
coretemp-isa-0000
Physical id 0: +41.0°C (high = +80.0°C, crit = +85.0°C)
Core 0: +40.0°C (high = +80.0°C, crit = +85.0°C)
Core 1: +40.0°C (high = +80.0°C, crit = +85.0°C)
i8k-virtual-0
Right Fan: 102210 RPM
CPU: +42.0°C
EDIT 3. I updated the Dell BIOS to the latest version (from 5 to 14), but to no avail. If I run the fan test with fwts, one test fails and 5 succeed. I can't get a more verbose output, though...
$ fwts fan
Running 1 tests, results appended to results.log
Test: Simple fan tests.
Test fan status. 5 passed, 1 failed
Load system, check CPU fan status.
