I have setuped a DNS server in Centos6.5 and its working with every client machines other than ubuntu, now i have issue with ubuntu While im trying to ping from desktop machine to DNS server as ping masterdns.arrivu.local i can't ping its return the as
sysadmin@localhost:~$ ping masterdns.arrivu.local
ping: unknown host masterdns.arrivu.local
But while i'm pinging with the ip address its working
sysadmin@localhost:~$ ping 192.168.1.15 -c 3
PING 192.168.1.15 (192.168.1.15) 56(84) bytes of data.
64 bytes from 192.168.1.15: icmp_seq=1 ttl=64 time=0.450 ms
64 bytes from 192.168.1.15: icmp_seq=2 ttl=64 time=0.445 ms
64 bytes from 192.168.1.15: icmp_seq=3 ttl=64 time=0.265 ms
--- 192.168.1.15 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.265/0.386/0.450/0.089 ms
Even i have checked using host its returning the IP
sysadmin@localhost:~$ host masterdns.arrivu.local
masterdns.arrivu.local has address 192.168.1.15
My issue is i want to ping and ssh using hostname instead of ip as below
ping masterdns.arrivu.local ssh root@masterdns.arrivu.local
IM using Desktop machine with ubuntu
sysadmin@localhost:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04 LTS
Release: 14.04
Codename: trusty
My Desktop ip is 192.168.1.99
While i did a dig from my desktop i got the reply from DNS
sysadmin@localhost:~$ dig masterdns.arrivu.local
; <<>> DiG 9.9.5-3-Ubuntu <<>> masterdns.arrivu.local
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 3101
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;masterdns.arrivu.local. IN A
;; ANSWER SECTION:
masterdns.arrivu.local. 86400 IN A 192.168.1.15
;; AUTHORITY SECTION:
arrivu.local. 86400 IN NS secondarydns.arrivu.local.
arrivu.local. 86400 IN NS masterdns.arrivu.local.
;; ADDITIONAL SECTION:
secondarydns.arrivu.local. 86400 IN A 192.168.1.51
;; Query time: 3 msec
;; SERVER: 192.168.1.15#53(192.168.1.15)
;; WHEN: Mon May 12 10:45:42 IST 2014
;; MSG SIZE rcvd: 124
NSlookup too worked
sysadmin@localhost:~$ nslookup arrivu.local
Server: 192.168.1.15
Address: 192.168.1.15#53
Address: 192.168.1.51
Address: 192.168.1.155
Address: 192.168.1.84
Address: 192.168.1.99
Address: 192.168.1.50
Address: 192.168.1.145
My Desktop Interface Info's
sysadmin@localhost:~$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet manual
auto br0
iface br0 inet static
address 192.168.1.99
network 192.168.1.0
netmask 255.255.255.0
broadcast 192.168.1.255
gateway 192.168.1.1
dns-nameservers 192.168.1.15 192.168.1.51
bridge_ports eth0
bridge_stp off
bridge_fd 0
bridge_maxwait 0
sysadmin@localhost:~$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 192.168.1.15
nameserver 192.168.1.51
search arrivu.local
There is no iptables deployed in desktop machine's or what I'm using as DNS server too
[root@masterdns ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
DNS Forward Entry
[root@masterdns named]# cat forward.arrivu
$TTL 86400
@ IN SOA masterdns.arrivu.local. root.arrivu.local. (
2014051001 ;Serial
3600 ;Refresh
1800 ;Retry
604800 ;Expire
86400 ;Minimum TTL
@ IN NS masterdns.arrivu.local.
@ IN NS secondarydns.arrivu.local.
@ IN A 192.168.1.15
@ IN A 192.168.1.51
@ IN A 192.168.1.155
@ IN A 192.168.1.84
@ IN A 192.168.1.99
@ IN A 192.168.1.50
@ IN A 192.168.1.145
masterdns IN A 192.168.1.15
secondarydns IN A 192.168.1.51
client IN A 192.168.1.155
sukumar IN A 192.168.1.84
babin IN A 192.168.1.99
server IN A 192.168.1.50
test IN A 192.168.1.145
DNS Reverse ENTRY
[root@masterdns named]# cat reverse.arrivu
$TTL 86400
2014051001 ;Serial
3600 ;Refresh
1800 ;Retry
604800 ;Expire
86400 ;Minimum TTL
@ IN PTR arrivu.local.
15 IN PTR masterdns.arrivu.local.
51 IN PTR secondarydns.arrivu.local.
155 IN PTR client.arrivu.local.
84 IN PTR sukumar.arrivu.local.
99 IN PTR babin.arrivu.local.
50 IN PTR server.arrivu.local.
145 IN PTR test.arrivu.local.
guide me to get fix buddies
