I use the 'alarm-clock-applet' to notify me every so often to take a break from looking at my screen and give my eyes a bit of a rest. The interface is clunky, but it works.
One issue I'm having, though, is that sometimes I don't notice when it goes off. The indicator icon in the Gnome panel (I use Flashback) turns yellow, but it's easy to miss.
It can be set to play a sound, but I'm often using my laptop in public settings where having an alarm go off at regular intervals wouldn't be acceptable.
The program does offer me the option of running a command when the alarm goes off. It would be great if I could set something that maybe placed notice on my screen that I couldn't ignore, or overlayed a transparent red over everthing, or something like that. I'm open to ideas, the point just being that it should be something that there is no way I can ignore it.
Is there any command I can run that would create some kind of completely blatant visual notification?
Braiam
  • 69,112
Questioner
  • 6,959
7 Answers7
You can use zenity to creates Graphical (GTK+) Dialog Boxes.
Try to add this command:
zenity --warning --text="Insert yout text here!"
or insert command inside a script.
Refer to zenity --help or man zenity for more help.
girardengo
  • 5,005
Make the alarm clock dim and colour your screen, with the option to snooze or dismiss:
  • Create a directory ~/bin
  • Copy the code for the script below, save it as alarm in~/bin.
  • Replace the value in snooze_time = 90 by the time you'd like to have as snooze interval. If you want, you can also play with the gamma- and brightness values, as long as you keep the syntax (the values in the first line after while snoozeoption == 1:).
  • Make the script executable. To save it in ~/bin and make the script executable is necessary, since the clock applet does not run composed commands; you need to be able call the script with a single command from the alarm clock applet.
You may have to log out/in before it works.
This is the script:
#!/usr/bin/python3
import subprocess
import time
# snooze time
snooze_time = 90
def get_screenname():
    screendata = subprocess.Popen(["xrandr"], stdout=subprocess.PIPE)
    return [line for line in screendata.communicate()[0].decode("utf-8").split("\n") if " connected" in line][0].split(" ")[0]
screen = get_screenname()
snoozeoption = 1
    subprocess.Popen(["xrandr", "--output", screen, "--gamma", "1:1:0.3", "--brightness", "0.6"])
    snoozeoption = subprocess.call(["zenity", "--question", "--text=What to do?",  "--ok-label=Dismiss", "--cancel-label=Snooze", "--title=Take a Break"])
    if snoozeoption == 1:
        subprocess.call(["xrandr", "--output", screen, "--gamma", "1:1:1", "--brightness", "1"])
        time.sleep(snooze_time)
    else:
        pass
  • In the alarm clock applet, set the command to run:
    alarm
Jacob Vlijm
  • 85,475
Install compizconfig-settings-manager
sudo apt-get install compizconfig-settings-manager
Open CCSM and go to Effects -> Wizard, choose some key combination to turn it on/off.
For me it is Ctrl+Shift+Alt+W.
Don't forget to enable Wizard.
Now you can try it. Press Ctrl+Shift+Alt+W to turn on/off animation.
I hope this is enough blatant for you.
Do Alarm
Now go to terminal, And run:
xdotool key ctrl+shift+alt+w
If you want to run it every 20 minutes, just add this command to crontab, with exporting DISPLAY variable.
execute crontab -e, and add this line
20 * * * * export DISPLAY=:0.0 && xdotool key ctrl+alt+shift+w
May be it would be better to turn off this effects automatically, especially if you are away from computer.
This command will do the same, but after 20 seconds it turns off.
20 * * * * export DISPLAY=:0.0 && xdotool key ctrl+alt+shift+w && sleep 20 && xdotool key ctrl+alt+shift+w
c0rp
  • 10,010
You can also use xmessage
It'll open a window that stays there until you close it.
xmessage 'Time to give my eyes a rest'
Type man xmessage for more options.
Parto
  • 15,647
There also exist a program called Workrave which is used to remind you to take a break from using a computer for configured set of time. It even shows exercise to make during a break in your office chair. I don't know if Workrave is in a repository, because I don't use Ubunutu but it is a Gnome program.
MaBu
Standard Desktop Notification could be used. Example:
notify-send 'Hello world!' 'This is an example notification.' --icon=dialog-information
References:
user.dz
  • 49,176
I have years used xcowsay. Pretty nice cow reminding and telling you whatever you want. Easy scripting:
xcowsay Hello world! --time=0 --cow-size=small
Lorenz Keel
  • 9,511
