11
I have shifted to Ubuntu only few weeks ago and after setting up Ubuntu my first step was to setup Eclipse for android development. I do not have any knowledge of Linux. I have searched on google and on this website for a comprehensive guide. Most of the guides are for older versions of Ubuntu and most of the instructions are not working for me. As I am not very well-versed in linux so often I had to start over with clean copy of Ubuntu. I have found this guide that have ultimately made the android development worked for me.
Hopefully it will help other users too.
M.Tarun
  • 5,121
The following are the steps in setting up android SDK on ubuntu 14.04:
# apt-get update and upgrade
sudo apt-get update
sudo apt-get upgrade
# For development
sudo apt-get install build-essential
# Git
sudo apt-get install git
git --version
#git version 1.9.1
#  (required for adb)
#bash: /usr/local/android-sdk-linux/platform-tools/adb: No such file or directory
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
#adb: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
sudo apt-get install g++-multilib
# Android SDK
# http://developer.android.com/sdk/index.html
# DOWNLOAD FOR OTHER PLATFORMS - SDK Tools Only - Linux 32 & 64-bit
# android-sdk_r22.6.2-linux.tgz
tar zxvf android-sdk_r22.6.2-linux.tgz
mv android-sdk-linux android-sdk_r22.6.2-linux
sudo mv android-sdk_r22.6.2-linux /usr/local/
sudo ln -s /usr/local/android-sdk_r22.6.2-linux /usr/local/android-sdk-linux
echo '' >> ~/.profile
echo '# Android SDK' >> ~/.profile
echo 'export ANDROID_SDK_HOME="/usr/local/android-sdk-linux"' >> ~/.profile
echo 'export PATH="$PATH:$ANDROID_SDK_HOME/tools"' >> ~/.profile
echo 'export PATH="$PATH:$ANDROID_SDK_HOME/platform-tools"' >> ~/.profile
source ~/.profile
# Android NDK
# https://developer.android.com/tools/sdk/ndk/index.html
# Linux 64-bit (x86)
# android-ndk-r9d-linux-x86_64.tar.bz2
tar xjvf android-ndk-r9d-linux-x86_64.tar.bz2
mv android-ndk-r9d android-ndk-r9d-linux-x86_64
sudo mv android-ndk-r9d-linux-x86_64 /usr/local/
sudo ln -s /usr/local/android-ndk-r9d-linux-x86_64 /usr/local/android-ndk-linux
echo '# Android NDK' >> ~/.profile
echo 'export ANDROID_NDK_HOME="/usr/local/android-ndk-linux"' >> ~/.profile
echo 'export PATH="$PATH:$ANDROID_NDK_HOME"' >> ~/.profile
source ~/.profile
# Android w/Eclipse
# Run android command
# android
# Android SDK Manager
#   Installed
#     Tools - Android SDK Tools 22.6.2
#   default checked
#     Tools - Android SDK Platform-tools 19.0.1
#     Tools - Android SDK Build-tools 19.0.3
#     Android 4.4.2 (API 19) All
#     Extras - Android Support Library 19.1
#   install 13 packages
# Eclipse - Help - Install New Software...
#   Name: ADT Plugin
#   Location: https://dl-ssl.google.com/android/eclipse/
#   Developer Tools, NDK Plugins
#   Eclipse restart
#   -> Android SDK "Location of the Android SDK has not been setup in the preferences" -> Close
#   -> Welcome to Android Development -> Use exsting SDKs
#   Existing Location: /usr/local/android-sdk-linux
#   -> Next -> Finish
# Confirm : Eclipse - Window - Preferences - Android
M.Tarun
  • 5,121
