Since my computer dates back to 2003, has an Intel Pentium M processor and is therefore not yet equipped with pae, I want to know if it is possible to install newer versions of Ubuntu as the version 12.04 LTS now? Lubuntu and Xubuntu have not worked for me and I do not want to, because their support will end soon.
I have successfully installed version 12.04 (the non-pae version), but should like to the current version Ubuntu 14, is that possible? Would an update to bring something? Because newer Ubuntu versions still run my knowledge, only with pae?
bain
  • 12,200
Ubuntu 14.04 (and derivatives like Xubuntu) supports an option called forcepae which enables it to run on many older Pentium M laptops. Keep in mind is that these laptops are a decade or so old, and often lack the memory and GPU required to smoothly run a desktop like Unity that is designed for modern 3D accelerated systems. It might be better to try one of the lightweight distributions like Xubuntu.
To enable forcepae:
  • Boot the 32-bit Ubuntu (or Xubuntu etc.) installer
  • When the image of the keyboard and little man in circle appears hit the Tab key
  • "Choose your language" popup appears. Use the cursor keys and hit the Enter key to choose your language
  • Press F6, a grey menu will popup with some boot options
  • Press escape to close the window
  • You will now see a line that says:
    Boot Options file=/cdrom/preseed/ubuntu.seed boot=casper initrd=/casper/initrd.lz quiet splash --
    Edit this line and add the forcepae parameter to the end:
    Boot Options file=/cdrom/preseed/ubuntu.seed boot=casper initrd=/casper/initrd.lz quiet splash -- forcepae
  • Hit the Enter key, hopefully Ubuntu will boot and the rest of your install will be successful. If you have graphical problems with Unity, or just find it slow, try a more lightweight distribution like Xubuntu.
bain
  • 12,200
