I need to get into recovery mode but pressing and holding shift does not work during boot, I also tried tapping shift and f8 but nothing happens, any suggestions? My system runs ubuntu 14.04 and here is my grub file:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=5
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Oli
  • 299,380
If the keys aren't working, you can actually edit the grub config file so that there is a little bit of a timeout for you.
sudo gedit /etc/default/grub
Change the value of GRUB_HIDDEN_TIMEOUT to a number in seconds. For example if you change it from 0 to 10, it will display the Grub menu for 10 seconds before automatically booting the first option.
Once you have made your desired change and saved the file, close it and run the following command to apply the changes:
sudo update-grub
After that
sudo reboot
Ashu_FalcoN
  • 2,118
Gerowen
  • 1,468
