I'm pretty new to ubuntu. I bought an acer aspire v5 laptop and installed Ubuntu. So far everything worked in the way I want it, except frescobaldi.
It's an editor for lilypond files. There's a midi-player included. I installed timidity and followed the instructions, however the midi player doesn't produce any sound. There's no error message or anything but it's pretty clear that it doesn't work. Every other sound application worked fine so far and I am able to use the timidity midi player to play my midi-files. Its just the built-in midi player in frescobaldi that doesnt work.
How to solve this?
I googled it for hours now and there doesn't seem to be anyone else with a similar problem.
This is a bit late, but for future reference I found that running
sudo timidity -iA
and then refreshing the MIDI ports in Frescobaldi (Edit->Preferences->MIDI Settings->Refresh MIDI ports) does the trick in my version (2.0.13).
eboix
  • 131
When using Frescobaldi in Ubuntu 15.10, the package libportmidi0 must be installed so that Midi playback works correctly.
Just install it using a terminal:
sudo apt-get install libportmidi0
Tested with QSynth, Patchage et VMPK midi tools.
Cf. https://bugs.launchpad.net/ubuntu/+source/frescobaldi/+bug/1572566
Danibix
  • 2,185
There’s a old discussion of this issue on the Frescobaldi lists, in the thread midi will not play from within frescobaldi.
The issue is that Frescobaldi is looking for an ALSA port providing a MIDI sequencer, and you need to persuade timidity to provide this.
You will need to start the timidity daemon by running
sudo service timidity start
then refresh the MIDI ports within Frescobaldi. This just now worked for me (Ubuntu 14.10) and may be all you need. But for completeness—
If this does not suffice, edit /etc/default/timidity; where it says,
# uncomment to override enabling triggered by availability of timidity-deamon
# TIM_ALSASEQ=false
(i.e., it defaults to enabled but you can override this) you might need to explicitly enable the ALSA port by changing the line to
TIM_ALSASEQ=true
But again, I found this step to be unnecessary, and probably so will you.
