I have installed the Citrix Receiver 13.0.0.256735 as described for Ubuntu 13.10 here: CitrixICAClientHowTo
The installation has succeded under Ubuntu 14.04 64 bit. But if I start the Citrix Receiver nothing happens.
Is there someone who has it running with Ubuntu 14.04?
jeremy
  • 103
tpf
  • 377
I followed the below steps and it worked for me:
  1. Download Citrix for Linux 64 bit from http://www.citrix.com/downloads/citrix-receiver/linux/receiver-for-linux-130.html
  2. Follow instructions in "Citrix Receiver 12.1 on Ubuntu 14.04 64-bit" section from https://help.ubuntu.com/community/CitrixICAClientHowTo
  3. In case of any Verisign certificate errors, export the certificates mentioned in the errors (eg: VeriSign Class 3 International Server CA - G3) from Mozilla Firefox: Edit > Preferences > Advanced > Encryption > View Certificates, and browse the list to find the VeriSign entries.
  4. Export the ones that are Class 3, one by one, in X509 format (PEM), and store them in your "cacert" folder with the .crt extension (you have to manually add the extension when you save the certificates). Copy it to /opt/Citrix/ICAClient/keystore/cacerts/.
Refer http://ubuntuforums.org/archive/index.php/t-1143029.html for more details.
muru
  • 207,228
This worked for me: http://www.tuxtrix.com/2013/11/how-to-install-citrix-receiver-13-on.html
If apt-get gives you any errors along the lines of "The following packages have unmet dependencies:" remember to sudo dpkg -P icaclient.
guntbert
  • 13,475
user287469
  • 24
Try the following:
sudo apt-get install libmotif4:i386 nspluginwrapper lib32z1 libc6-i386 libxp6:i386 libxpm4:i386 libasound2:i386
from: https://www.citrix.com/downloads/citrix-receiver/receivers-by-platform/receiver-for-linux-121.html
Note: Get the download from the "For 64-bit Systems" section. If the Download popup doesn't work in Chrome, use Firefox.
cd ~/Downloads
mkdir ica_temp
dpkg-deb -x icaclient_12.1.0_amd64.deb ica_temp
dpkg-deb --control icaclient_12.1.0_amd64.deb ica_temp/DEBIAN
sudo gedit ica_temp/DEBIAN/control
sudo dpkg -i icaclient-modified.deb
sudo ln -s /usr/share/ca-certificates/mozilla/* /opt/Citrix/ICAClient/keystore/cacerts
/opt/Citrix/ICAClient/wfcmgr &
*For the full tutorial click here. *
Korkel
  • 1,168
