I installed Ubuntu Gnome and did a lot of system configurations and installed all my programmes. Now once of a sudden the booting sequence hangs just before the login screen. If I hit Ctrl + Alt + Backspace I will get to the login screen. However, login just ends with a black screen and the desktop does not show.
I looked into https://askubuntu.com/a/223634. Accessed the terminal via Ctrl+Alt+F3 and tried the following:
  • ls -lah does not show .Xauthority
  • ls -ld /tmp seems to be okay regarding writing rights
  • dpkg-reconfigure gdm did not show any results
  • Even after killing X and login in, I can find .xsession-errors
Can you help me to debug this issue? Thanks.
Xorg.0.log output: http://paste.ubuntu.com/7418243/
One line says: [ 337.141] setversion 1.4 failed: Permission denied Does that hint to anything?
Sina
  • 1,063
I created a new user via the terminal and it turns out I could login with no problem with it. So I just went on and reset my own ~/.profile by renaming it. I then just had to redo all the gnome settings. Not ideal but it works at least again.
Sina
  • 1,063
