I'm following this tutorial to setup a NAT gateway: https://help.ubuntu.com/community/Internet/ConnectionSharing#Ubuntu_Internet_Gateway_Method_.28iptables.29
With simple eth0 as WAN and eth1 as LAN it works. Then I tried to bridge eth1 and eth2 into br0 as LAN, and modified the script a little bit:
sudo iptables -A FORWARD -o eth0 -i **br0** -s 192.168.0.0/24 -m conntrack --ctstate NEW -j ACCEPT
sudo iptables -A FORWARD -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
sudo iptables -t nat -F POSTROUTING
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
This is not working as expected. The result is only clients connected to eth1 is able to go through the NAT.
Basically I want all clients connected to eth1 and eth2 are in same LAN and they both can go through the NAT to internet.
Did I make any mistake in the script? Thanks!
Update #1:
Here is my configuration:
wexia@ubuntu12:/etc$ ifconfig -a
br0       Link encap:Ethernet  HWaddr 00:15:5d:83:5f:0c
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::215:5dff:fe83:5f0c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:41 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:560 (560.0 B)  TX bytes:7454 (7.4 KB)
eth0      Link encap:Ethernet  HWaddr 00:15:5d:83:5f:07
          inet addr:10.122.122.97  Bcast:10.122.123.255  Mask:255.255.254.0
          inet6 addr: 2001:4898:20:1:215:5dff:fe83:5f07/64 Scope:Global
          inet6 addr: 2001:4898:20:1:2d00:ef97:5f57:33d9/64 Scope:Global
          inet6 addr: fe80::215:5dff:fe83:5f07/64 Scope:Link
          RX packets:78422 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2591 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:11743173 (11.7 MB)  TX bytes:479989 (479.9 KB)
eth1      Link encap:Ethernet  HWaddr 00:15:5d:83:5f:0c
          RX packets:390 errors:0 dropped:0 overruns:0 frame:0
          TX packets:316 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:26740 (26.7 KB)  TX bytes:41439 (41.4 KB)
eth2      Link encap:Ethernet  HWaddr 00:15:5d:83:5f:0e
          RX packets:64 errors:0 dropped:0 overruns:0 frame:0
          TX packets:483 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3702 (3.7 KB)  TX bytes:57163 (57.1 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1278 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1278 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:139832 (139.8 KB)  TX bytes:139832 (139.8 KB)
wexia@ubuntu12:/etc$ brctl show
bridge name bridge id       STP enabled interfaces
br0     8000.00155d835f0c   no      eth1
                            eth2
wexia@ubuntu12:/etc$ cat network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto br0
iface br0 inet static
bridge_ports eth1 eth2
  address 192.168.1.1
  netmask 255.255.255.0
Wei Xia
  • 53
Make sure that all the interfaces involved with the bridge are set to up. (It's possible to have an interface as part of a bridge, but not have it set to being up, so no traffic will go through that "port").
sudo ifconfig eth1 up
sudo ifconfig eth2 up
sudo ifconfig br0 up
Also, check your work on the bridge to make sure it has the interfaces you are expecting:
sudo brctl show
Make sure that you have the LAN IP address assigned on the bridge interface instead of either of the ethernet interfaces that are part of the bridge/switch:
ifconfig eth1
ifconfig eth2
(Neither of them should list an IP address). If one of them does, try something like:
sudo ip addr del 192.168.0.1/24 dev eth1
Make sure your bridge interface does have it:
ifconfig br0
(It should list the address). If it does not have the address, do this:
 sudo ip addr add 192.168.0.1/24 dev br0
Another thing I would try checking: See if any clients attached to eth2 can ping anything on eth1. If so, then the bridge and interfaces (and their up/down state) is probably set up right, and I would look at the IPtables rules. If they can't talk to each other, than it's probably not with IPtables, and probably something with the bridge or interfaces that are part of it.
Azendale
  • 12,021
