For some reason it won't dectect my music and it says Volume N/A and it won't let me change it. You can find my dotfiles here. Yes I am running them locally and let me know if you need some screenshots of the problem.
Thanks in advance -- maybe someone could just give me their config?
jkt123
  • 3,600
Regarding your audio-output (Volume N/A):
Change the content of your mpd.conf, located at /home/Username/.mpd/mpd.conf to:
music_directory    "/home/nathan/music"
playlist_directory "/home/nathan/.mpd/playlists"
db_file            "/home/nathan/.mpd/mpd.db"
log_file           "/home/nathan/.mpd/mpd.log"
id_file            "/home/nathan/.mpd/mpd.pid"
state_file         "/home/nathan/.mpd/mpdstate"
audio_output {
      type  "pulse"
      name  "mpd pulse-audio-output"
audio_output {
      type  "alsa"
      name  "mpd alsamixer-output"
audio_output {
type               "fifo"
name               "fifo_visualizer"
path               "/tmp/mpd.fifo"
format             "44100:16:2"
After that open a terminal window and type mpd + enterkey, followed by ncmpcpp + enterkey, then hit 8key, to enter the Outputs window (see screenshot), where you then can either choose mpd pluse-audio-output or mpd alsamixer-output.
One of those two should actually work for you!!
Now for your other problem (It won't dectect my music): Please refer to one of the many guides to set up mpd/ncmpcpp properly: 01 | 02 |03.
If you come across any problems during the setup procedure please edit your original question and specifically add the information there!! GL
image with incorrect spelling of "pulse"
v2r
  • 9,707
