Yep, this question has been asked a hundred times, and I have searched everywhere, to no avail.
The title says it all really.
I have an OpenVPN server (On ubuntu), and I can connect to it through my client (Windows 8) ...
The problem starts when I try to route ALL traffic through the VPN.
I have added the push flags in server.conf:
push "redirect-gateway def1"
push "dhcp-option DNS 8.8.8.8"
When I connect from the client, the client outputs:
Wed May 07 21:38:40 2014 SENT CONTROL [StretchVPN-CA]: 'PUSH_REQUEST' (status=1)
Wed May 07 21:38:41 2014 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 8.8.8.8,route-gateway <Remote Router IP>,ping 10,ping-restart 120,ifconfig 192.168.0.201 255.255.255.0'
Wed May 07 21:38:41 2014 OPTIONS IMPORT: timers and/or timeouts modified
Wed May 07 21:38:41 2014 OPTIONS IMPORT: --ifconfig/up options modified
Wed May 07 21:38:41 2014 OPTIONS IMPORT: route options modified
Wed May 07 21:38:41 2014 OPTIONS IMPORT: route-related options modified
Wed May 07 21:38:41 2014 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed May 07 21:38:41 2014 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed May 07 21:38:41 2014 open_tun, tt->ipv6=0
Wed May 07 21:38:41 2014 TAP-WIN32 device [Local Area Connection 4] opened: \\.\Global\{1F145805-92FC-454E-8FD9-0A6017DD4AD1}.tap
Wed May 07 21:38:41 2014 TAP-Windows Driver Version 9.9
Wed May 07 21:38:41 2014 Notified TAP-Windows driver to set a DHCP IP/netmask of 192.168.0.201/255.255.255.0 on interface {1F145805-92FC-454E-8FD9-0A6017DD4AD1} [DHCP-serv: 192.168.0.0, lease-time: 31536000]
Wed May 07 21:38:41 2014 Successful ARP Flush on interface [35] {1F145805-92FC-454E-8FD9-0A6017DD4AD1}
Wed May 07 21:38:46 2014 TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
Wed May 07 21:38:46 2014 C:\WINDOWS\system32\route.exe ADD <Remote Router IP> MASK 255.255.255.255 172.20.10.1
Wed May 07 21:38:46 2014 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
Wed May 07 21:38:46 2014 Route addition via IPAPI succeeded [adaptive]
Wed May 07 21:38:46 2014 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 192.168.0.3
Wed May 07 21:38:46 2014 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
Wed May 07 21:38:46 2014 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 192.168.0.3
Wed May 07 21:38:46 2014 Initialization Sequence Completed
I have tried using the flags on the client side when opening the connection:
openvpn --config "C:\Program Files\OpenVPN\config\client.ovpn" --redirect-gateway def1 --route-method exe
But still, when I go to whatsmyip.org, it still says my clients ip.
Has anyone had this problem and managed to solve it?
Many thanks
