-1
I use ubuntu 12.04
My error msg:
sam@sam:~/code/pcl_standalone/vfh_dir$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
  libbullet
The following NEW packages will be installed:
  libbullet
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
6 not fully installed or removed.
Need to get 0 B/963 kB of archives.
After this operation, 2456 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 796153 files and directories currently installed.)
Unpacking libbullet (from .../libbullet_2.80-0_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/libbullet_2.80-0_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/libHACD.so.2.80', which is also in package libbullet2.80 2.80.2-ubuntu1~precise1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
How to solve it?
Braiam
  • 69,112
sam
  • 6,921
You can't have two versions of libaries, like libbullet in the same system. Remove one of them. I presume you are using a PPA. If that's the case contact the PPA maintainer.
To remove them:
sudo dpkg -r libbullet2.80
or
The maintainers of PPA's are only reached by mail, normally.
Braiam
  • 69,112
