On my Lenovo X240 I have installed Ubuntu 14.04. Everything, including the LAN connection, works very smoothly except from the WiFi.
The computer connects to a WiFi hotspot but after a few bytes transmitted the connection breaks down completely.
EDIT: --> If the hotspot is less crowded, i.e. if I switch off my other clients, then the connection works more or less stable but still with occasional troubles. <--
The hotspot is OK, since other devices do not experience any troubles.
Any ideas? I am not too deep in Ubuntu, please give me advice if you need more information on the hardware.
This is what iwconfig gives me:
iland@note121:~$ iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:"thrasher(at)hajod.de"
Mode:Managed Frequency:2.412 GHz Access Point: 7C:4F:B5:C8:D2:C4
Bit Rate=54 Mb/s Tx-Power=16 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=70/70 Signal level=-35 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:6 Missed beacon:0
And this the hardware configuration from sudo lshw -c network:
*-network
description: Ethernet interface
product: Ethernet Connection I218-LM
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: eth0
version: 04
serial: 28:d2:44:40:96:64
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=2.3.2-k duplex=full firmware=0.6-3 ip=192.168.1.11 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:61 memory:f0600000-f061ffff memory:f063e000-f063efff ioport:3080(size=32)
*-network
description: Wireless interface
product: Wireless 7260
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 83
serial: 5c:51:4f:58:a5:c5
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=3.13.0-24-generic firmware=22.24.8.0 ip=192.168.1.10 latency=0 link=yes multicast=yes wireless=IEEE 802.11abgn
resources: irq:66 memory:f0400000-f0401fff
