Historically, there is an "Enable Wireless" option that I can have ticked or unticked that is just beneath the "Enable Networking" option when I right click on the network bar.
Suddenly this disappeared one day, and I can't connect to wireless, nor does the option even exist to enable wireless.
The output for rfkill list all is below:
rfkill list all
1: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: yes
Hard blocked: no
And that is all. There is no wireless that is being displayed.
The output for sudo lshw -C network is:
    *-network
       description: Ethernet interface
       product: Ethernet Connection I218-LM
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: eth0
       version: 04
       serial: 28:d2:44:4d:b6:89
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=2.0.0-k duplex=full firmware=0.6-3 ip=10.0.28.48 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:57 memory:f0600000-f061ffff memory:f063e000-f063efff ioport:3080(size=32)
  *-network UNCLAIMED
       description: Network controller
       product: Wireless 7260
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 83
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:f0400000-f0401fff
Does anyone know how I can enable wireless? I have also tried:
sudo /etc/init.d/networking restart
and have checked to make sure drivers are up to date as well.
There is the same discussion : I recommend to you to follow it, to resolv your problem !
"Enable Wireless" option is disabled in network settings
craken
  • 196
