When I tried to convert my audio files from WMA to MP3, I get an error message that I need to search for a plugin. See pictures below.
How can I convert these audio files?
jkt123
  • 3,600
Vitor Mazuco
  • 1,461
You can use ffmpeg or the VLC media player to convert WMA files to MP3. Once you have VLC installed, convert your file by:
  1. Open VLC and select Media -> Convert / Save
  2. Add your WMA file and click Convert/Save
  3. Select Audio - MP3 from the conversion drop-down
  4. Choose a destination for your file
  5. Click Start
With ffmpeg, you can convert the file from the command-line using this code:
ffmpeg -i input.wma -ab 32 output.mp3
The -b option specifies the bitrate, so you may want to change that to fit your needs.
jkt123
  • 3,600
