I have Ubuntu already installed on my computer that I just bought, and I have a copy of Windows 7. I like the feel of Ubuntu, and plan on trying it out, but I have many Windows-specific applications.
So, my question is, is it possible for me to dual boot Windows from Ubuntu. I understand people usually dual boot Ubuntu from Windows, but I have it the other way around. What do you suggest, or is this possible?
Sure you can, but Windows is known to disregard installations of other operating systems.
You will probably need to edit the Windows 7's Boot Configuration Data (BCD) to add the entry for Ubuntu. The easiest way is to use a BCD editor like EasyBCD: www.softpedia.com After installing Windows, install EasyBCD and add the entry for Ubuntu.
This will make a dual-boot system but will still use the Windows' Boot Manager. If you would like to use GRUB as a boot manager, you can find more info on reinstalling GRUB here: help.ubuntu.com
vanogrid
  • 126
Yes it is possible. See here
https://help.ubuntu.com/community/WindowsDualBoot
Rex
  • 1,737
Yes, you can dual-boot Ubuntu and Windows 7 even if Windows 7 was installed first. The answer here is very good.
jkt123
  • 3,600
Yes it is possible and the steps are listed on this thread.
However if you just want to use windows for a couple of hours to finish some work using a windows specific application and don't want to see any kind of booting issues then I suggest you to go for virtual box. You can install virtual box in your Ubuntu box and then Install windows as a guest OS. The only catch here is you need to have more RAM. If your PC have more than 4GB ram then definitely you can try this
Jasnan
  • 121
