-2
How do I log in as root? I can't use aptitude unless I am root. I have broken / held packages that I can't install.
Zanna
  • 72,312
bruce
  • 2,977
You don't really log in as root directly, but you can use sudo. sudo -i gives you a root prompt, and putting sudo before a command runs it as root. The root account by default on ubuntu is designed to avoid people logging in for security reasons, and also probably because sudo does that task of logging in as root for you - why create extra work for yourself? ;)
megubyte
  • 1,164
