I was running Ubuntu 13.10 with no issues and decided to upgrade to Ubuntu 14.04 recently. Since I've upgraded I've noticed that my mouse starts to lag after I play a movie via xbmc or a video on Youtube in full screen mode.
It usually happens after playing a fullscreen video for around an hour. My mouse works perfectly on startup.
I have just tried a fresh install of 14.04 and I've got the same problem.
When I say the mouse lags, I mean that after I move the mouse it takes 1-2 seconds to respond and is continuously lagging ie. once it starts lagging it's constant and I have to reboot to fix the problem. I've tried restarting x but that doesn't fix it.
I am using a Logitech K400 mouse/keyboard combo with a logitech unified receiver.
Any suggestions?
gyrex
  • 349
5 Answers5
12
I actually found the issue to this problem and thought I'd do the right thing and post it. It would seem that the positioning of the bluetooth receiver in particular USB ports had an impact with the reception between the keyboard/mouse (probably something to do with the fact that it's a mini-pc and the processor and other radio affecting devices are situated so closely together and so close to the USB ports).
I changed the logitech bluetooth receiver to a different USB port and my mouse/keyboard are working like a charm now.
Thank you to everyone for their input and help!
gyrex
  • 349
I had the same problem, but i fixed it. You need to install "CompizConfigSettingsManager" and switch off "sync with VBlank" in OpenGL tab. After that i installed PPA and update drivers for video card. It helped me. Here is video solution: http://www.youtube.com/watch?v=cIQZv6MXzno
This can occur if your bluetooth dongle is next to a wifi chipset for example. Just switch side to connect my USB dongle solved my laggy keyboard (my mouse was already fluid before).
A fresh install rather than a upgrade is always cleaner.
Nicolas
I cannot find a solution to my problem so I am going to downgrade to 13.10. This is a real shame since I would have liked to run a LTS release of Ubuntu.
gyrex
  • 349
This solved this problem, although kernel dowgrade is not a good thing:
sudo apt-get install linux-image-3.4.0-3-goldfish
Ludwig
