After moving a video clip used by kdenlive from one folder to another, kdenlive can no longer find the video clip and tells me "missing clip".
How do I tell kdenlive where the new location of the video clip is? Or do I have to delete the missing clip, add it back in, then re-add all of the crops/transitions/effects back onto the track?
A J
  • 11,557
RJ-Adam
  • 243
The only way I've found to fix this is to save my project, close KDEnlive, then relaunch and open the project. KDEnlive will pop up a box with all the missing clips and give you the option to search recursively to find them.
Once it finds each clips' new folder, click "OK".
Be sure to save your project again after KDEnlive has made the changes.
(aside: would be nice if KDEnlive had an option to perform this recursive search when right-clicking a clip that has gone "missing"... maybe someday)
Mark
  • 126
I think the easiest way to leave the clip in its new location and still have kdenlive see it, while preserving your edits, would be to symlink it. In the terminal cd to the folder where it used to be. Then, enter:
ln -s path-to-clip's-new-location clip's-filename
For example, if the clip were named clip.avi and your username were dave and the clip now resided in the Videos subfolder of your home folder, then the command would be, after changing into the directory where kdenlive expects the clip to be:
ln -s /home/dave/Videos/clip.avi clip.avi
I hope that helps.
Drew Noakes
  • 5,878
Probably, not the most elegant, yet quite efficient way to re-map data location to your KDEnlive file is just open the project file (which is *.kdenlive) in text editor and manually replace required pieces of paths by mask. I.e. you moved your data from
'/home/video/prj'
to
'home/video/prj/1'
So everywhere mask '/home/video/prj' is found, it must be replaced with 'home/video/prj/1'. When you complete all changes, just save the file and that's it. It opens in KDEnlive with whole new mapped paths to your data.
Igor
  • 51
