I installed Lubuntu 14.04 on my wife's old netbook. I cannot get the wireless to work. I initially installed the STA driver, but it did not work. I then removed it and installed the b43 driver. Synaptic Package Manager shows that firmware-b43-lpphy-installer and b43-fwcutter are installed and that bcmwl-kernel-source is not installed.
Yet when I go to the Additional Drivers screen is says that Broadcom BCM4312 is not working and is using bcmwl-kernel-source (which I know is not installed). It also shows "unknown device" and gives me the option to continue using manually installed driver If I try to do so, nothing happens. There is also a grayed out option that says using non-free firmware for Linux kernel from linux-firmware-non-free.
Any help would be appreciated. I am at my wits end, and the wife is threatening to go buy a Windows computer.
OK, it is not a blacklist issue. Here is the result of the dmesg | grep b43 command:
[17.652124] b43-phy0: Broadcom 4312 WLAN found (core revision 15)
[17.728574] b43-phy0: Found PHY: Analog 6, Type 5 (LP), Revision 1
[22.268301] b43-phy0: Loading firmware version 478.104 (2008-07-01 00:50:23
