How to find my current JAVA_HOME in ubuntu? I have to set java_home path when installing maven.
To display JAVA_HOME variable path, type in terminal:
echo $JAVA_HOME
If nothing appears then set it with this:
export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64
This will differ according to your JDK type and version.
For displaying it again, follow the first command.
Follow JREs from different vendors on the same system, for using different JDK's or switch between JDK's.
- 119,640
- 4,109
If you have JDK 1.6 (corresponding to Java 6) or a newer version installed, you should have a program named jrunscript in your PATH. You can use this to find the corresponding JAVA_HOME. Example:
$ jrunscript -e 'java.lang.System.out.println(java.lang.System.getProperty("java.home"));'
/opt/local/jdk1.7.0_76/jre
You could set the environment variable like this:
$ export JAVA_HOME="$(jrunscript -e 'java.lang.System.out.println(java.lang.System.getProperty("java.home"));')"
Note that the JRE doesn't include jrunscript, so this will only work if you install the JDK, not just the JRE.
- 541
Another portable options is to extract the absolute path of the JRE from java:
export JAVA_HOME=`type -p java|xargs readlink -f|xargs dirname|xargs dirname`
The absolute java path is passed to dirname twice to remove /bin/java from the end. Complete extraction of the directory goes as follows:
$ type -p java
/usr/bin/java
$ readlink -f /usr/bin/java
/usr/lib/jvm/java-8-oracle/bin/java
$ dirname /usr/lib/jvm/java-8-oracle/bin/java
- 444
Just run a command
sudo update-alternatives --config java
It will give something like
Es gibt nur eine Alternative in Link-Gruppe java (die /usr/bin/java bereitstellt): /usr/lib/jvm/java-8-oracle/jre/bin/java
From this you have /usr/lib/jvm/java-8-oracle/ as java home. You may now export it to JAVA_HOME variable
export JAVA_HOME=/usr/lib/jvm/java-8-oracle/
Now echo $JAVA_HOME show it
- 289
To take into account the update-alternatives mechanism:
$ update-alternatives --query java | grep 'Value: ' | grep -o '/.*/jre'
$ export JAVA_HOME="$(update-alternatives --query java | grep 'Value: ' | grep -o '/.*/jre')"
- 91
For Java 9 and later:
This answer https://askubuntu.com/a/657468/963 uses the enclosed Nashorn JavaScript engine Nashorn to print out the java.home system property. Nashorn is being deprecated so an alternative is to use jshell introduced in Java 9.
echo 'System.out.println(java.lang.System.getProperty("java.home"));' | jshell -
which on my Ubuntu 18.10 system prints out:
/usr/lib/jvm/java-11-openjdk-amd64
- 4,101
I use this in Ubuntu LTS (14.04 / 16.04):
[ -L /etc/alternatives/java ] &&
export JAVA_HOME="$(readlink -f /etc/alternatives/java | sed -e 's/\/jre\/bin\/java$//')"
- 163
Set Java environment variables
The PPA also contains a package to automatically set Java environment variables, just run command:
sudo apt install oracle-java8-set-default
From this article: Install Oracle Java 8 / 9 in Ubuntu 16.04, Linux Mint 18
- 133
to get JAVA_HOME:
update-alternatives --query java | grep 'Value: ' | sed 's/Value: \(.*\)\/bin\/java/\1/'
e.g. returns </opt/Oracle_Java/jre1.8.0_202>
if </etc/alternatives/java> points to
</opt/Oracle_Java/jre1.8.0_202/bin/java>
to set JAVA_HOME:
export JAVA_HOME="$(update-alternatives --query java | grep 'Value: ' | sed 's/Value: \(.*\)\/bin\/java/\1/')"
- 113
- 5
For versions that support -XshowSettings:properties:
While alternatives may remain popular I mostly use jenv and occasionally sdkman, which all introduce a level of indirection; if you are happy to ask java itself:
java -XshowSettings:properties -version |& grep -Po '(?<=java.home = )(.*)'
This is not available in Java 6:
docker run --rm openjdk:6 java -XshowSettings:properties -version
Unrecognized option: -XshowSettings:properties
Could not create the Java virtual machine.
It is available since Java 7:
dk run --rm openjdk:7 bash -c "java -XshowSettings:properties -version |& grep -Po '(?<=java.home = |java.home=)(.*)'"
/usr/lib/jvm/java-7-openjdk-armhf/jre
- 111
