-1
I am a COMPLETELY new user to linux and have been using most of my programs through wine. Take for example this program : http://www.atlauncher.com/download/jar/ which, when unpacked has no executable files. I'm not sure if I am looking for the wrong type of file but I would really appreciate some help on how to get downloads like this with no obvious runnable files up and running.
Thanks in advance
saiarcot895
  • 10,917
Matthew
That particular file you have downloaded is a Java file; by default, Linux, will not grant executable rights to files - you need to grant that privilege.
Quick answer
A) You need Java (unless you have that):
sudo apt-get install openjdk-7-jre
B) You'll need to correct the permissions:
cd ~/Downloads/
chmod +x <file>.jar
C) To run: java -jar <file>
Ash
  • 459
  • 13
You don't extract .jar files, because they are Java Archives and should therefore be executed using Java (or in case of a library included in your project). Ubuntu opens .jar using the Archive Manager by default because it is actually a ZIP file.
So you should install Java first. If you haven't already, you can execute the following commands to install OpenJDK (an open source version of Java):
sudo apt-get update
Now you can open the .jar file using java -jar file.jar in the terminal or by double clicking it in your file manager.
