16
I'm running Ubuntu 14.04. I generally have the unity launcher in auto-hide mode. Problem starts if the desktop has been locked and then unlocked. Then the unity launcher does not disappear again.
CosmoRon
  • 163
5 Answers5
18
Avoid holding down the Super button.
When locking the screen with Super + L the Super key is normally held down before pressing Super. But holding down Super is in itself a shortcut to get the Shortcut Help Screen up. By using this to lock the computer, you make the sidebar reveal itself before it's "interrupted" by the screen locking. This is the reason why using Alt+Ctrl+L does not produce the same effect: none of those keys have any effect on the sidebar, dash or the Help screen.
Either rapidly tap Super+L simultaneously (DO NOT HOLD DOWN Super), use Alt+Ctrl+L or find a way to remove the Super shortcuts for the Dash/Sidebar.
EDIT: Also found that if your sidebar gets stuck, you can tap Super twice to get rid of it.
Zanna
  • 72,312
16
You may have triggered the four-finger multi-touch command for revealing the launcher. Try swiping four fingers to the left.
Source: https://wiki.ubuntu.com/Multitouch
Found completely by accident.
I solve it by changing the button with CCSM (CompizConfig Settings Manager):
  1. If not already done, install compizconfig-settings-manager with the following command:
    sudo apt-get install compizconfig-settings-manager
  2. Open CCSM.
  3. Select "Desktop" -> "Ubuntu Unity Plugin" -> "Launcher"
  4. Turn the "Hide Launcher" from "Never" to "Autohide".
Screenshot
Byte Commander
  • 110,243
This is considered a fixed bug and is resolved by Unity 7.2.2+14.04.20140714-0ubuntu1. The following command will bring you to the latest version. You may need to log out and back causing unity to restart to see the resolution.
sudo apt-get upgrade unity
Here is the official bug report: https://bugs.launchpad.net/ubuntu/+source/unity/+bug/1320438
flickerfly
  • 7,509
i had this problem ! you have to move mouse cursor to left top and press rightClick mouse + leftclick mouse and drag to center left . hope work it for you ;)
Amin ak
