85
I just created a new user & its home folder & need to delete it now & also I cant find my old user's Downloads,Documents,Pictures,etc folder in /home/olduser & also .Xauthority file. Dont know how it deleted. I executed startx command by pressing Alt+Ctrl+F3when new user wasnt able to log in.
I deleted user from Users & Groups but its home folder didnt get deleted. How can I fix this?
  • How can I delete new user's home folder safely?
  • How can restore my old documents,downloads,folder?
  • If not then how can I create brand new /home folder & link with OS?
Deepen
  • 4,109
8 Answers8
97
to list all users :
cut -d: -f1 /etc/passwd
To remove user :
sudo userdel username
To remove home directory :
sudo rm -r /home/username
To add a home directory to an existing user :
create a home directory
chown this directory for the user
sudo usermod -d /home/directory user
nux
  • 39,152
67
You can use the more advanced deluser command:
sudo deluser --remove-home user
You can also try the the --remove-all-files option. From man deluser:
By  default,  deluser  will  remove  the user without removing the home
directory, the mail spool  or any other files on the  system  owned  by
the  user.  Removing  the home directory and mail spool can be achieved
using the --remove-home option.
The --remove-all-files option removes all files on the system owned  by
the  user.  Note  that  if you activate both options --remove-home will
have no effect because all files including the home directory and  mail
spool are already covered by the --remove-all-files option.
As can be expected, the second option may take a while to complete.
muru
  • 207,228
12
Best way is to use the OPTIONS provided by the userdel command.
sudo userdel -rfRZ <username>
This will:
  1. Force delete
  2. Files in the user's home directory will be removed along with the home directory itself and the user's mail spool. Files located in other file systems will have to be searched for and deleted manually.
  3. Apply changes in the CHROOT_DIR directory and use the configuration files from the CHROOT_DIR directory.
  4. Remove any SELinux user mapping for the user's login.
Hope this helps!
Rush W.
  • 313
Delete/Remove User Account and Files
# deluser --remove-home tecmint      [On Debian and its derivatives]
# userdel --remove tecmint           [On RedHat/CentOS based systems]
But before this there are some other steps:
  1. Lock User Accounts in Linux
# passwd --lock tecmint
  1. Find and Kill All Running Processes of User
# pgrep -u tecmint
# killall -9 -u tecmint
  1. Backup User Data Before Deleting
tar jcvf /user-backups/tecmint-home-directory-backup.tar.bz2 /home/tecmint
source ref: link
Bubba
  • 31
If you have already deleted the user through the normal userdel <username> and the home directory still exist like i experienced in mine, you just need to run rm -rf /home/<username>
HCM
sudo userdel -r olduser
deletes users homdir and mail spooler
  1. Go to settings and type users.
  2. Under user click on change settings and type the root password.
  3. You must have another administrator user.
  4. Turn off the administrator option for the user you want to delete.
  5. Click on Remove User at the bottom of the page
Bogo
I LIKE THIS,one-line MASTER COMMAND on my system-administrator job.
sudo Killall -u <username> && sudo deluser --remove-home <username> && sudo
rm -rm /home/<username>
