34
Running 14.04 in virtualbox 4.3.8
Unable to detect the guest additions.iso when i selected the guest additions.iso in the IDE Secondary Master.
No problem, so I used wget and downloaded the iso into the guest ubuntu headless.
when I attempt to load the iso from inside using these commands:
sudo mkdir /media/iso
sudo modprobe loop
sudo mount filename.iso /media/iso -t iso9660 -o loop
At the sudo modprobe loop, I got the following error:
modprobe: ERROR: ../libkmod/libkmod.c:556 kmod_search_moddep() could not open moddep file '/lib/modules/3.13.0-24-generic/modules.dep.bin'
Here are my lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04 LTS
Release:    14.04
Codename:   trusty
EDIT:
When I typed
ls /lib/modules/*/modules.dep.bin
I get back
/lib/modules/3.11.0-20-generic/modules.dep.bin  /lib/modules/3.13.0-24-generic/mo‌​dules.dep.bin /lib/modules/3.5.0-49-generic/modules.dep.bin
Kim Stacks
  • 1,076
8 Answers8
24
Thanks to Braiam comments, I have solved it using
sudo apt-get install --reinstall linux-image-3.13.0
Kim Stacks
  • 1,076
20
No need to reinstall linux image
sudo depmod
works fine for me. credit goes to @pabouk
Tal
  • 187
It may be system changes waiting for a reboot after updates. My installation was pointing to the wrong /lib/modules/<version>, but it worked itself out after a reboot.
#:/ $ sudo modinfo iptable_nat
libkmod: ERROR ../libkmod/libkmod.c:557 kmod_search_moddep: could not open moddep file '/lib/modules/4.1.18+/modules.dep.bin'
modinfo: ERROR: Module alias iptable_nat not found.
sshow
  • 211
 # apt-get install --reinstall linux-image-`uname -r`
This will do the trick unless you want to upgrade your kernel.
In my case on a raspberry 3b+ running on the raspbian OS, trying to run a cryptsetup command which uses dm_mod in the kernel, which was not included in my kernel, this helped without needing a re-flash of the raspberry:
sudo apt-get install --reinstall --yes raspberrypi-bootloader raspberrypi-kernel
sudo reboot
Taken from this thread: https://www.raspberrypi.org/forums/viewtopic.php?t=282802
My cryptsetup command worked afterwards, while having the same error like OP stated: Cannot initialize device-mapper. Is dm_mod kernel module loaded? previously.
Ok. I couldn’t believe it but I got the same error and after much troubleshooting, I’ve discovered that the /boot was NOT mounted during this kernel module rebuild.
Once mounted, the problem went away for me.
Turns out that I was a good “victim” of a good security practice (as outlined by CISecurity).
John Greene
  • 135
Oddly, I'm experiencing this issue if I specify an ExecStart stanze in a systemd unit containing two commands connected with &&, e.g.
ExecStart=/sbin/modprobe zfs && /usr/local/sbin/zpool import -d /dev data
This might be incorrect, but then systemd would still need to fail with a helpful error message - like any program ever existing.
The command chain can be expressed with bash -c, e.g.
ExecStart=/bin/bash -c '/sbin/modprobe zfs && /usr/local/sbin/zpool import -d /dev data'
(mind the simple quotes '' instead of double quotes "").
-1
If you can't access the network you can do
dpkg-reconfigure linux-image-$(uname -r)
It worked for me
Zanna
  • 72,312
Alex
