Possible Duplicate:
How can I find which desktop enviroment I am using?
I'm a desktop user and boot straight into it. What's the best way to tell which desktop package I'm using (both kind and version), despite what would normally come with Ubuntu, and despite how it's configured or visually customized? I assume this info is stored in a configuration file somewhere for viewing, or queryable in some programmatic manner.
John K
  • 1,163
In Ubuntu you can use following commands:
  • echo $DESKTOP_SESSION: This command return ubuntu when you are using Unity and ubuntu-2d when you are using Unity 2D and ...
or
  • sudo grep "Starting session" /var/log/lightdm/lightdm.log: Because of last version of Ubuntu use lightdm as display manager you can see last line of the lightdm.log file.
When you find out which desktop environment you are using, you can go to a package manager program like "synaptic" and check what is your desktop environment version.
If you go to System > Administration > System Monitor, enter you password when prompted and then select the System tab, you will see the details of your current install, eg:
Ubuntu
Release 10.10 (maverick)
Kernel Linux 2.6.35-28-generic
GNOME 2.32.0
Where, in this case, the desktop environment is Gnome 2.32.0
You can also try the following commands in the terminal
lsb_release -a
uname -a
cat /proc/version
Install the sysinfo Install sysinfo application from Ubuntu Software Center. It can give all the information you need.
