Sony Vaio VGN-NW240F
Network controller: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
$ lspci -vv -s
Subsystem: Foxconn International, Inc. T77H126.00 802.11bgn Wireless Half-size Mini PCIe Card
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 17
Region 0: Memory at d2500000 (64-bit, non-prefetchable) [size=64K]
Capabilities: <access denied>
Kernel driver in use: ath9k
$ modinfo ath9k
filename:       /lib/modules/3.13.0-24-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license:        Dual BSD/GPL
description:    Support for Atheros 802.11n wireless LAN cards.
author:         Atheros Communications
srcversion:     BAF225EEB618908380B28DA
alias:          platform:qca955x_wmac
alias:          platform:ar934x_wmac
alias:          platform:ar933x_wmac
alias:          platform:ath9k
alias:          pci:v0000168Cd00000036sv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000036sv0000185Fsd00003027bc*sc*i*
[alias...]
depends:        ath9k_hw,mac80211,ath9k_common,cfg80211,ath
intree:         Y
vermagic:       3.13.0-24-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        00:A5:A6:57:59:DE:47:4B:C5:C4:31:20:88:0C:1B:94:A5:39:F4:31
sig_hashalgo:   sha512
parm:           debug:Debugging mask (uint)
parm:           nohwcrypt:Disable hardware encryption (int)
parm:           blink:Enable LED blink on activity (int)
parm:           btcoex_enable:Enable wifi-BT coexistence (int)
parm:           bt_ant_diversity:Enable WLAN/BT RX antenna diversity (int)
parm:           ps_enable:Enable WLAN PowerSave (int)
My network works perfectly well with this computer on windows 7, and with various other computers and devices. I installed Ubuntu 14.04 today, and it works perfectly, except for the wifi.
When I try to connect (wifi icon, name_of_network), a popup asking for the password keeps appearing every minute or so, and it does not connect. The password is correct.
I tried to delete the network from the connection list (wifi icon, edit connections), restart my computer and try again, to no avail.
Ethernet works perfectly.
I have to assume that it is related to Ubuntu, since the wireless card is recognized and can scan the different networks available.
$ rfkill list
0: sony-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
I do not know Ubuntu 14.04 well enough to even try anything.
Any suggestions?
Zanna
  • 72,312
William Abma
  • 261
6 Answers6
10
So, my issue was fixed. I'm not extremely sure how, but here is what I did:
sudo service network-manager restart
Maybe that will help others who have this problem, if that was the solution of course.
William Abma
  • 261
Please excuse the lack of formality in this answer - just a quick notice to others for the only thing that worked for me after hours of searching and trying different stuff.
I spent ages trying to get something to work - in the end it became obvious that actually the network card itself worked (because it was fine on another OS); that the wifi network worked (because I could sit there on my phone using it just fine); that the password was correct; and that I could connect to the internet through my wired connection.
The problem it turned out for me was that the network card I have is a bit... not that awesome.
First I found out here what my network card was
sudo lshw -class network
(It's a Realtek RTL8821AE 802.11ac PCIe Wireless Network Adaptor, so I used "RTL8821AE" in my searches)
Then I searched for the driver and it took a while but eventually I found this thread which said that there was a new... I'm gonna say driver (?!) ... and followed the instructions. It was only through the github link that I could actually work out where the ... I'm gonna say driver (?!) ... was and downloaded it on my laptop, unzipped it and copied it over on a USB stick. Then I just did the make commands etc. Boom! it worked :)
And I also had to use this command sometimes to clear a cache or whatever:
muru
  • 207,228
ja_him
  • 121
This is not a solution rather a workaround, you can use nmcli command line interface for the network manager. For example:
nmcli d wifi connect <Your-SSID> password <Your-Password>
Let me know if you are able to connect with this.
If anyone else is having the same problem as me where you have to run sudo service network-manager restart every time you login for your wifi to work. I have found a permanent fix for my network adapter that the newer release of ubuntu broke. Ignore my previous comments about downgrading the kernel as the main problem was the new wpasupplicant package in 14.04.
My solution involved getting this ppa: deb http://ppa.launchpad.net/mathieu-tl/nm/ubuntu saucy main it has Ubuntu's 13.10 network manager package and wpasupplicant package. I went to synaptic and downgraded only the wpasupplicant package. I never have to run the command sudo service network-manager restart again.
answerSeeker
  • 901
  • 26
I got the same problem when I was on my home network and switching between a wired and wireless connection. After working fine for a couple of days, the wireless was suddenly no longer working. I could see the wireless network, but when trying to connect it continuously asked for a password.
I fixed it by installing the new driver for my network card and switching my router off and on.
I hope this helps anyone with similar issues!
DVI
I installed "wifi radar" form softwere center Started it left everything as it was and hit save and exited it. Now my wifi works fine hope this works for everyone. PS. Im running kubuntu 14.04
stacey
