I am trying to install SQL Developer on Ubuntu 14.04. I have followed some tutorials but none of them worked. So I am asking you if you know how to install SQL Developer.
I installed SQL Developer with these steps:
(See the comments—this might not be necessary)
Download and re-install newest Ubuntu 14.04 LTS from Ubuntu website.Install Java:
Java Version JDK 7:
sudo apt-get install openjdk-7-jdk openjdk-7-jre icedtea-7-plugin sudo update-alternatives --config javaJava Version JDK 8 (in some installations this is a requirement instead of 1.7):
sudo add-apt-repository ppa:webupd8team/java sudo apt-get update sudo apt-get install oracle-java8-installer sudo update-alternatives --config java
Download SQL Developer from Oracle website (I chose Other Platforms download).
Extract file to
/opt:sudo unzip sqldeveloper-*-no-jre.zip -d /opt/ sudo chmod +x /opt/sqldeveloper/sqldeveloper.shLinking over an in-path launcher for Oracle SQL Developer:
sudo ln -s /opt/sqldeveloper/sqldeveloper.sh /usr/local/bin/sqldeveloperEdit
/opt/sqldeveloper/sqldeveloper.shand replace it's content to:#!/bin/bash unset -v GNOME_DESKTOP_SESSION_ID cd /opt/sqldeveloper/sqldeveloper/bin ./sqldeveloper "$@"or (to prevent error:
./sqldeveloper: Permission denied)#!/bin/bash unset -v GNOME_DESKTOP_SESSION_ID cd /opt/sqldeveloper/sqldeveloper/bin && bash sqldeveloper $*Run SQL Developer:
sqldeveloperNote: When you run Sql Developer at the first time, you need to specify the path of JDK's folder. In my computer, JDK stored at /usr/lib/jvm/java-1.7.0-openjdk-amd64 For Java 8 and Ubuntu 16+ /usr/lib/jvm/java-8-oracle
Finally, create desktop application for easy to use:
cd /usr/share/applications/ sudo vim sqldeveloper.desktopadd this lines:
[Desktop Entry] Exec=sqldeveloper Terminal=false StartupNotify=true Categories=GNOME;Oracle; Type=Application Icon=/opt/sqldeveloper/icon.png Name=Oracle SQL Developerthen type:
sudo update-desktop-database
- 33
- 1,203
Here's how I did it on Ubuntu, I think this is the easiest way and will give you a package that you can easily reuse later (but you can't redistribute according to OTN license):
- Downlod the sql developer package from here.
Install the sql developer package as the following.
sudo apt-get install sqldeveloper-package debhelper openjdk-7-jdk openjdk-7-jre icedtea-7-pluginNow all what you need to do is to run the command (you might have a different version)
make-sqldeveloper-package sqldeveloper-4.1.3.20.78-no-jre.zip- This will generate a debian package that you can use to install sql developer.
Now install the resulting .deb package using the command (Your deb might have a different version too):
sudo dpkg -i sqldeveloper_4.1.3.20.78+0.2.4-1_all.debYou're now done with the installation. in my case it needed the new java 8 then you will need to run the following commands.
sudo add-apt-repository ppa:webupd8team/java sudo apt-get update sudo apt-get install oracle-java8-installerFinally you need to provide the java path for oracle sql developer at the first run in my case it was at
/usr/lib/jvm/default-java/.
- 556
- 376
- 3
- 8
I installed version 17.4 on Ubuntu 16.04 GNOME like so.
- Verify installation of OpenJDK 8 and location at
/usr/lib/jvm/java-8-openjdk-amd64If absent, install withsudo apt install openjdk-8-jdk. Newer versions of Java may work as well. - Accept license agreement and download "Other Platforms" version
- Unzip in my home directory
- Run from the commandline
~/sqldeveloper/sqldeveloper.shonce to add location of Java. Enter/usr/lib/jvm/java-8-openjdk-amd64 Create the desktop icon for future access from my GUI menu.
# /home/USERNAME/.local/share/applications/sqldeveloper.desktop [Desktop Entry] Name=Oracle SQL Developer GenericName=SQL Developer X-GNOME-FullName=Oracle SQL Developer Comment= A free integrated development environment that simplifies the development and management of Oracle Database Keywords=sql;developer;oracle;db;database Exec=/home/USERNAME/sqldeveloper/sqldeveloper.sh Terminal=false Type=Application StartupNotify=true Icon=/home/USERNAME/sqldeveloper/icon.png Categories=Admin X-AppStream-Ignore=true
Make the desktop file executable
chmod +x /home/USERNAME/.local/share/applications/sqldeveloper.desktop
- 3,869
Install Java 6. (It didn't work for me with Java 1.7):
sudo add-apt-repository ppa:webupd8team/java sudo apt-get update sudo apt-get install oracle-java6-installerDownload the SQL Developer from here and choose Other platforms. (You'll need an account in order to download it). Open the Downloads directory:
cd ~/Downloadsand extract the file to
/opt:sudo unzip sqldeveloper-*-no-jre.zip -d /opt/Make the launch script executable:
sudo chmod +x /opt/sqldeveloper/sqldeveloper.shOpen sqldeveloper:
sudo /opt/sqldeveloper/sqldeveloper.shThe first time you'll be asked to enter the jvm location. In my case (and probably yours if you have followed the first step), the location is:
/usr/lib/jvm/java-6-oracle.
- 36,350
- 1,475
I installed oracle sqldeveloper in ubuntu 17.10 using the following method:
- Accept license agreement and download oracle linux rpm: http://www.oracle.com/technetwork/developer-tools/sql-developer/downloads/index.html
Install alien:
sudo apt-get install alien
Install the rpm using alien:
sudo alien -i sqldeveloper-17.3.1.279.0537-1.noarch.rpm
Run sql developer by using the following command in the terminal
sqldeveloper
Make sure to change the version of your rpm. For this to be successful you have to have oracle java 8 or above installed in your machine.
