I tried to access the acceleration tap under system under settings and I can not. The tab is greyed out like their is no data available.
If the corresponding Virtual Machine is running then the options under acceleration tab(Settings->System->Acceleration) would be grayed out.
So poweroff the virtual machine in-order to enable Hardware Virtualization(intel vt-x).
Avinash Raj
  • 80,446
If you have :-
  1. VirtualBox's error - something likes " VT-X is not available".
  2. Host os is 64 bits with more than 4 GB of ram.
  3. Guest os is 32 bits
Lest's try to reduce VirtualBox's base memory to be under 4 GB.
mrlamud
  • 126
