12
So I upgraded from Ubuntu 12.04 to 14.04 and now I see Floppy in my Home Folder tree how do I remove it?
what I did since Ubuntu 12.04 is:
  • Edit /etc/fstab to remove reference to floppy.
  • Edit /etc/modprobe.d/blacklist and add this line at the end: blacklist floppy
  • Run: sudo update-initramfs -u
  • Run: sudo update-grub
  • Restarted the system.
I checked /etc/modprobe.d/blacklist it contains blacklist floppy like it was before the upgrade but now I can see floppy in my Home Folder tree. Is there something else I need to change in 14.04?
MathCubes
  • 5,732
JoKeR
  • 7,062
Problem solved! Found the solution on Ubuntu 14.04 in terminal run:
  1. echo "blacklist floppy" | sudo tee /etc/modprobe.d/blacklist-floppy.conf
  2. sudo rmmod floppy
  3. sudo update-initramfs -u
works right away.
JoKeR
  • 7,062
