I need some help. The installation went fine but when restarted I get the following message
Serious error were found while checking the disk drive for /.
I select option M for manual recovery and it says
Root file system check failed.
What can I do?
Thanks
user68186
  • 37,461
Satya
I faced exactly same issue. Then I realised that the way I did instllation was wrong. Do it in these steps.
  1. Download iso image file (Do not unzip it or run WUBI.exe)
  2. Prepare a Bootable USB drive (Need Min 3 GB free space)
  3. Download a utility called Universal-USB-Installer-1.9.5.2
  4. Run this Utility from your windows environment
  5. It will ask for a iso file source, point to that
  6. It will also ask for a USB, point to that and it will create the bootable usb for u
  7. Now restart ur machine, Go to ROM based set up(F10 or F12)
  8. Choose Boot from USB as first priority
  9. That will give u option. Ubuntu will load either to be tried or installed. First try and the install..
I am sharing this URL which will guide you. http://www.techspot.com/community/topics/step-by-step-beginners-guide-to-installing-ubuntu-11-10.172128/
Eric Carvalho
  • 55,453
