I have tried so many things, that I have no idea how to resolve this.
I want to update my packages on my server. For that I do the following:
sudo apt-get update
sudo apt-get upgrade
I then get the following response:
peter@blackbox:/etc/apt$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libavahi-common-data : Breaks: libavahi-common-data:i386 (!= 0.6.30-5ubuntu2) but 0.6.30-5ubuntu2.1 is installed
libavahi-common-data:i386 : Breaks: libavahi-common-data (!= 0.6.30-5ubuntu2.1) but 0.6.30-5ubuntu2 is installed
E: Unmet dependencies. Try using -f.
Following the instructions:
peter@blackbox:/etc/apt$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libcommons-jxpath-java libplexus-archiver-java libmaven-plugin-tools-java libcdi-api-java libplexus-containers-java linux-headers-3.2.0-44-generic linux-headers-3.2.0-39-generic libwagon-java libmodello-java
linux-image-3.2.0-55-generic libsisu-guice-java libplexus-classworlds-java libmaven2-core-java libjtidy-java linux-image-3.2.0-37-generic linux-headers-3.2.0-52-generic libhttpclient-java libaspectj-java libservlet2.4-java
libplexus-velocity-java linux-headers-3.2.0-32 linux-headers-3.2.0-33 linux-headers-3.2.0-40 linux-headers-3.2.0-35 linux-headers-3.2.0-36 linux-headers-3.2.0-37 linux-headers-3.2.0-43 linux-headers-3.2.0-38 linux-headers-3.2.0-44
linux-headers-3.2.0-39 linux-headers-3.2.0-45 linux-headers-3.2.0-51 linux-headers-3.2.0-52 linux-headers-3.2.0-53 linux-headers-3.2.0-48 linux-headers-3.2.0-55 libcommons-jexl-java linux-headers-3.2.0-56 libosgi-compendium-java
libplexus-cipher-java libguava-java libplexus-classworlds2-java libplexus-build-api-java libplexus-i18n-java linux-image-3.2.0-45-generic libnetty-java linux-headers-3.2.0-55-generic libplexus-interactivity-api-java libqdox-java
libgeronimo-jpa-2.0-spec-java linux-headers-3.2.0-37-generic libcglib-java linux-image-3.2.0-53-generic linux-image-3.2.0-48-generic libxbean-java libcommons-net2-java libsaxon-java libdoxia-sitetools-java glassfish-javaee
libitext1-java linux-image-3.2.0-40-generic libcommons-collections-java linux-headers-3.2.0-45-generic linux-image-3.2.0-56-generic libosgi-foundation-ee-java libasync-http-client-java libplexus-ant-factory-java libplexus-cli-java
libplexus-container-default-java aspectj linux-headers-3.2.0-32-generic libeasymock-java linux-image-3.2.0-43-generic linux-image-3.2.0-38-generic linux-headers-3.2.0-53-generic linux-headers-3.2.0-48-generic fop libaopalliance-java
libgeronimo-interceptor-3.0-spec-java libplexus-io-java libplexus-bsh-factory-java libclassworlds-java libplexus-interpolation-java libosgi-core-java linux-headers-3.2.0-40-generic linux-headers-3.2.0-35-generic
linux-image-3.2.0-51-generic linux-headers-3.2.0-56-generic libhttpcore-java libcommons-httpclient-java libplexus-containers1.5-java libcommons-vfs-java linux-headers-3.2.0-43-generic linux-headers-3.2.0-38-generic libslf4j-java
libasm3-java libjsoup-java libfop-java libaether-java libatinject-jsr330-api-java libsisu-ioc-java libcommons-configuration-java libmaven-reporting-impl-java velocity libxmlgraphics-commons-java linux-headers-3.2.0-51-generic
libwerken.xpath-java libgeronimo-osgi-support-java libnetbeans-cvsclient-java libplexus-utils-java linux-headers-3.2.0-33-generic libplexus-sec-dispatcher-java libcommons-validator-java linux-image-3.2.0-44-generic
linux-image-3.2.0-39-generic libmaven-scm-java libdoxia-java libcommons-digester-java libbatik-java libjetty-java libcommons-io-java libplexus-utils2-java linux-headers-3.2.0-36-generic libganymed-ssh2-java
linux-image-3.2.0-52-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 68 not upgraded.
8 not fully installed or removed.
Need to get 0 B/21.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
dpkg: error processing libavahi-common-data (--configure):
libavahi-common-data:amd64 0.6.30-5ubuntu2 cannot be configured because libavahi-common-data:i386 is in a different version (0.6.30-5ubuntu2.1)
dpkg: error processing libavahi-common-data:i386 (--configure):
libavahi-common-data:i386 0.6.30-5ubuntu2.1 cannot be configured because libavahi-common-data:amd64 is in a different version (0.6.30-5ubuntu2)
dpkg: dependency problems prevent configuration of libavahi-common3:i386:
libavahi-common3:i386 depends on libavahi-common-data; however:
Package libavahi-common-data:i386 is not configured yet.
dpkg: error processing libavahi-common3:i386 (--configure):
dependency problems - leaving unconfigured
libavahi-common3 depends on libavahi-common-data; however:
Package libavahi-common-data is not configured yet.
dpkg: error processing libavahi-common3 (--configure):
dpkg: dependency problems prevent configuration of libavahi-client3:
libavahi-client3 depends on libavahi-common3 (>= 0.6.22); however:
Package libavahi-common3 is not configured yet.
dpkg: error processing libavahi-client3 (--configure):
dpkg: dependency problems prevent configuration of libavahi-client3:i386:
libavahi-client3:i386 depends on libavahi-common3 (>= 0.6.22); No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
however:
Package libavahi-common3:i386 is not configured yet.
dpkg: error processing libavahi-client3:i386 (--configure):
dpkg: dependency problems prevent configuration of libavahi-core7:
libavahi-core7 depends on libavahi-common3 (>= 0.6.16); however:
dpkg: error processing libavahi-core7 (--configure):
dpkg: dependency problems prevent configuration of avahi-daemon:
avahi-daemon depends on libavahi-common3 (>= 0.6.16); however:
avahi-daemon depends on libavahi-core7 (>= 0.6.24); however:
Package libavahi-core7 is not configured yet.
dpkg: error processing avahi-daemon (--configure):
libavahi-common3
libavahi-client3
libavahi-core7
avahi-daemon
Anyone has any idea how to resolve this?
Update 30-04-2014:
As Avinash Raj suggested I have hold back the libavahi-common-data and run his commands. I get the following:
peter@blackbox:~$ sudo apt-get autoremove
peter@blackbox:~$ sudo apt-get -f install
Correcting dependencies... failed.
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
