I want to install gimp in 13.10. I follow these procedure to install gimp.
sudo add-apt-repository ppa:otto-kesselgulasch/gimp-edge
sudo apt-get update
sudo apt-get install gimp
But after i update the system, when i go for the last command.(sudo apt-get install gimp) It show this error
 gimp : Depends: libgimp2.0 (>= 2.9.1.119-build~33915~145295a~saucy0~ppa) but it is not going to be installed
        Depends: libgimp2.0 (<= 2.9.1.119-z) but it is not going to be installed
        Depends: libgegl-0.3-0 but it is not going to be installed
How can i install the gimp and resolve the error. please help me.
The procedure to install gimp is sudo apt-get install gimp
When using a third party repository you are mostly on youw own and if there is any issue with the repository you must contact with the person that maintains it.
xangua
  • 7,277
