11
I have an Optimus laptop, a Dell XPS 15 L502, which I've had for a few years and have tried various things on (bumblebee, nvidia-prime, linux kernel optimus support).
The graphics card is an NVIDIA GT 540M.
I upgraded to Ubuntu 14.04 a few days ago and wanted to try nvidia-prime again (it wasn't working so great for me on 13.10), but nvidia-settings only tells me that it is not supported.
Software and Updates recognises the Nvidia card and drivers. Nvidia Settings currently gives me this:
** Message: PRIME: No offloading required. Abort
** Message: PRIME: is it supported? no
I've tried to purge and reinstall nvidia drivers a dozen times, I've tried with and without xorg.conf files, but still always the same thing.
I've followed all the guides I could find on Stack Overflow, Ask Ubuntu, and various other places.
EDIT: I was having problem with booting into "low-graphics mode", but that was due to a bad lightdm configuration that broke when I upgraded. I also had some segmentation fault issues with nvidia-settings installing the wrong version of itself (this was fixed by reinstalling just nvidia-settings).
EDIT: Have also found this bug report: https://bugs.launchpad.net/ubuntu/+source/nvidia-prime/+bug/1283439
Zanna
  • 72,312
dieuwe
  • 133
I have the same portable, I was using bumblebee before. But since 14.04 it was not working anymore and so now I switched to nvidia-prime. This is what I did:
Steps
  • Install Nouveau driver through "Software & updates"
  • Remove bumblebee or other installed nvidia drivers:
    sudo apt-get purge bumblebee*
    sudo apt-get purge nvidia-*
  • An then reboot
  • Install nvidia 331-updates driver through "Software & updates" (should also install nvidia-settings and nvidia-prime)
  • Then reboot
Now run again nvidia-settings. This did it for me, more info here.
geoffrey
  • 146
I had a similar problem. This is just a note to whomever else might find it useful.
Things started working once I re-enabled optimus from BIOS.
It seems the developers didn't do enough error handling. There should really be a bug report about that.
MadMike
  • 4,275
  • 29
  • 50
vpapro
  • 31
