28
On ubuntu, in the /etc/apt/, there are two files: sources.list and sources.list.distUpgrade. But I only know they are used to update system. However, what are the the difference between them? by the way, what the GPG keys used for? when I update the sources.list using ubuntu source list generator, should I update GPG keys as well?
Thanks !
tqjustc
  • 880
  • 15
  • 28
When you upgrade between distro versions, .list files in /etc/apt/sources.list.d get commented out. The original versions of those files get backed up with the .distUpgrade extension, and that's what you're seeing. Other than sitting there and being backups, I don't think the .distUpgrade files do anything.
I guess Ubuntu (Debian?) does this out of the presumption that .list files will be incompatible across distro versions, but as a packager, this is pretty inconvenient. Packages like google-chrome install a special cronjob just to work around this issue and un-comment-out their .list file after a dist upgrade.
-4
type man apt-get in terminal
 upgrade
       upgrade is used to install the newest versions of all packages
       currently installed on the system from the sources enumerated in
       /etc/apt/sources.list. Packages currently installed with new
       versions available are retrieved and upgraded; under no
       circumstances are currently installed packages removed, or packages
       not already installed retrieved and installed. New versions of
       currently installed packages that cannot be upgraded without
       changing the install status of another package will be left at
       their current version. An update must be performed first so that
       apt-get knows that new versions of packages are available.
   dist-upgrade
       dist-upgrade in addition to performing the function of upgrade,
       also intelligently handles changing dependencies with new versions
       of packages; apt-get has a "smart" conflict resolution system, and
       it will attempt to upgrade the most important packages at the
       expense of less important ones if necessary. The dist-upgrade
       command may therefore remove some packages. The
       /etc/apt/sources.list file contains a list of locations from which
       to retrieve desired package files. See also apt_preferences(5) for
       a mechanism for overriding the general settings for individual
       packages.
sohel4r
  • 494
