Just installed Ubuntu 12.04. The default display driver has fixed my resolution to 1024x768. The only other option I see for selection is 800x600. Is there a way to increase my resolution to see 1280x800 as many sites recommend? My desktop is not using the full screen. It's sticking to the left side. Have about 4 inches of dark unused area to my right.
Have been trying to configure this since 3 days. No progress made so far :-(
As per some of the suggestions in the comments, I tried the following steps.
Step 1: cvt 1280 800
Output:
# 1280x800 59.81 Hz (CVT 1.02MA) hsync: 49.70 kHz; pclk: 83.50 MHzModeline "1280x800_60.00" 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync
Step 2: xrandr --newmode "1280x800_60.00"   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync
Step 3: xrandr --verbose --addmode LVDS1 1280x800_60.0
Output:
X Error of failed request:  BadMatch (invalid parameter attributes)
Major opcode of failed request:  149 (RANDR)
Minor opcode of failed request:  18 (RRAddOutputMode)
Serial number of failed request:  27
Current serial number in output stream:  28
Is this due to refresh rate? My xrandr gives the following output now:
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 4096 x 4096
LVDS1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768       60.0*+
800x600        60.3     56.2
640x480        59.9
VGA1 disconnected (normal left inverted right x axis y axis)
TV1 disconnected (normal left inverted right x axis y axis)
1280x800_60.00 (0xd5)   83.5MHz
h: width  1280 start 1352 end 1480 total 1680 skew    0 clock   49.7KHz
v: height  800 start  803 end  809 total  831           clock   59.8Hz
Naveen Karnam
  • 101
ONLY If installing drivers for your GPU doesnt help. [Should be at Software & Updates >> additional drivers] Try looking here : How to make my maximum screen resolution to be detected by Ubuntu? Look at the answer provided by Venki I had the same problem and that helped me. But on the first command instead of :
cvt 2048 1536
I used:
gtf 1280 1024 60
gtf [horizontal res] [vertical res] [refresh rate]
If you get odd looking fonts after following the linked post, use :
sudo add-apt-repository ppa:no1wantdthisname/ppa
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install fontconfig-infinality
Not sure if that package above will help but it did help me. If it doesnt you can uninstall it by: sudo apt-get remove --purge fontconfig-infinality sudo ppa-purge ppa:no1wantdthisname/ppa
Kyodo
  • 395
12.04 additional drivers should offer an Nvidia driver for your geforce 6150 gpu, The one to use is current, driver 304.117. Then you can use the "Nvidia X server settings" program to adjust the resolution to 1280x800. In 14.04, the drivers are found under the "software and updates" program's 4 tab.
ubfan1
  • 19,049
