12
I have been experimenting with nginx as a webserver for php files. I come from an Apache background but I wanted to try it. I recently had an issue with it and needed to switch back to Apache. I removed it using apt-get remove nginx.
This worked fine and I installed Apache and life was good. I restarted my computer and somehow nginx started up. I didn't understand. I tried to remove it again and I got the message:
$ sudo apt-get remove nginx
Reading package lists... Done
Building dependency tree
Package 'nginx' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
If I look for the program (screenshot):
$ which nginx
/usr/sbin/nginx
Does anyone know if I am doing something wrong or what the next step to removing it would be?
I am using Xubuntu 14.04.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
arty
  • 123
nginx is a metapackage, so you need to remove whatever was installed by this package. If doing sudo apt-get autoremove doesn't do the trick, you can run sudo apt-get remove nginx-core nginx-full nginx-light nginx-extras nginx-naxsi nginx-common (you probably have only one of these packages installed, but the command shouldn't fail).
saiarcot895
  • 10,917
sudo apt-get remove --purge nginx* will remove whatever is installed and is related to nginx, including configuration files. It will also list packages available in repositories which match the regex nginx* and are not installed.
There is a difference between apt-get remove and apt-get purge. The --purge option removes also the configuration files. It is useful for a clean reinstall.
Typing the command:
will result in:
The following packages will be REMOVED:
nginx-common*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
(Reading database ... 55416 files and directories currently installed.)
Removing nginx-common ...
Purging configuration files for nginx-common ...
ftcosta
  • 31
