I'm trying to setup an easy mail server to support my "lost password" function in my website.
I'd like to know if Exim is good or not, or is there any better solution?
I would also like to know that it isn't easy to manage an smtp server (such as blocking junk mail, or being hacked, etc), does setting up a send-only mail server cause any security issues?
Thanks!
KKyang
  • 165
Simple example to setup postfix with satellite SMTP
  1. install postfix
    sudo aptitude install postfix
  2. configure postfix
    sudo vi /etc/postfix/smtp_auth
    add your smtp authentication information in /etc/postfix/smtp_auth:
    smtp.foo.bar user@host:password
    and generate the postfix lookup table file (/etc/postfix/smtp_auth.db) using
    sudo postmap /etc/postfix/smtp_auth
    add the relayhost (outgoing smtp server e.g. smtp.foo.bar on port 587, depending your relay host info) information to /etc/postfix/main.cf:
    relayhost = [smtp.foo.bar]:587
    add the following lines to /etc/postfix/main.cf in order to enable smtp-auth for outgoing mails:
    smtp_sasl_auth_enable = yes smtp_sasl_password_maps = hash:/etc/postfix/smtp_auth smtp_sasl_security_options = noanonymous
  3. restart postfix
    sudo service postfix restart
mcantsin
  • 1,264
I had a similar problem and here is how I did. I created a gmail account for my daemon. I set up filters from gmail.com.
And I send my mail using http://iqjar.com/jar/sending-emails-from-the-raspberry-pi/
The guide is for raspberry pi but it will work as long as you use a debian or alike)
If you protected your server from bruteforce (fail2ban ?), it should be fine.
