Lately was the release of Ubuntu 14.04. I was using 12.04 on my laptop but it was installed with wubi installer. I tried to search for a wubi with 14.04 but didn't find it. Can Is there a way to install 14.04 alongside Windows 7 on one HDD. I had and idea to to upgrade 12.04 to 14.04 but I don't know will this work. Any ideas ?
You can upgrade from 12.04 LTS to 14.04 LTS. Open Software Updater and let it check for all updates. When it is done, it should inform you that there is a new version of Ubuntu available, and give you an option to upgrade.
If not, check the Software & Updates under the Updates tab there is a dropdown list at the bottom for Notify Me Of New Ubuntu Versions; select Long Term Support versions and then exit the window. Restart Software Updater let it run again. You should now be informed of a new version which you may upgrade to.
- 340
I met a lot of people that had some serious problem after upgrading to 14.04. So I recommend you to do a clean installation (after saving your data !) or to keep 12.04.
Here is how I did a clean install (adapt for yourself) :
- I downloaded the ubuntu x64 iso (choose depending your CPU) (http://www.ubuntu.com/download/desktop)
- I used lili usb creator from windows to make a bootable usb key. (http://www.linuxliveusb.com/) USE 2.0 USB KEY AND PORT, 3.0 WONT WORK.
- I started on the live usb (choose try ubuntu)
Using Gparted, I made these partitions (sda3 to sda7 are one ubuntu installation) :
/dev/sda1 * 2048 524290047 262144000 7 HPFS/NTFS/exFAT
/dev/sda2 524290048 1500540927 488125440 7 HPFS/NTFS/exFAT
/dev/sda3 1500542974 1953523711 226490369 5 Extended
/dev/sda5 1500542976 1668314460 83885742+ 83 Linux
/dev/sda6 1668317184 1701871615 16777216 82 Linux swap / Solaris
/dev/sda7 1701873664 1953523711 125825024 83 Linux
- I launched installation, choose other (custom installation)
- I used sda5 as /, sda7 as /home.
- You can guess how to end the installation. If you install windows afterwards, remember to use boot-repair.
I recommend you to put your Ubuntu installation at the end of the disk. This way, it will be easier to increase extended partition size using unused space of previous partition.
- 285
Wubi isn't no longer available (what I've heard on the Forums a time ago).
It is more advisable to set up a normal dual boot system; you'll get:
- increased performance
- more stable Ubuntu
- a handy way to fix W7 should a problem occur
- a very easy way to handle files fromout 2 operating systems
To be short: Wubi was a way to install Ubuntu alongside Windows, but it is vunerable since Windows can have its issues what could lead that you can't bootup your Ubuntu. So, a dual boot with separate partitions is a more plausible way of working with Ubuntu.
The installer is very easy to use, and choosing partition-sizes is also very easy. Please refer to the Wiki of Ubuntu should extra help be nessecary.
Succes!
- 1,184
